Dear guys.
My factory is using wincc Runtime professional V18 for SCADA.
Before, The construction company only hands over to us the .fwc file without Original Tia Portal project.
Because this company didn't exist anymore, so we couldn't get Original Tia Portal project.
How can i get Connectinal list and HMI tag list from .fwc file?
Thank Much.
[?]: HMI tag list from Fwc file of WINCC Professional
manhkhuong
Re: [?]: HMI tag list from Fwc file of WINCC Professional
try [LINK]: Data Analyzer (Decoder) for FlexRT.fwx, ProTool.fwd, Portal.fwc
viewtopic.php?t=21938
rename TIA Portal Wincc basic/Comfort/Advanced *.fwc to *.fwx
georg_demmler
the data analyser was for Protool and WinCCFlex and perhaps TIA in early versions (V13 or V14). I tried it with a TIA project V18. You get perhaps nformation about name of
screens, name of variables but no the addresses. Perhaps it is possible to get the fwc-file and I give you all the information about your HMI (what is possible with the program).
georg_demmler
and if you see the date / time of the files in the screen of the answer of CoMod it is 2008 and now we have 2025.
PORTAL V18 with Comfort panel fwc = show tags adress M*.* and non_optimized DB (click on "Adress sort" tab)
With PORTAL image fwc works unstable and may close itself
с образами Портала работает нестабильно и может сама закрыться
показывает адреса M*.* и неоптимизированных DB - для просмотра надо кликнуть на Закладку "Сортировка по адресу", чтобы появились адреса
georg_demmler
thank for your help - but you have another program.
The program what I have is from the megaupload
I have a version where I see for the russian language only ??????????.
And the second - you open a *.fwc - I can't not open a *.fwc - file. In the top of the program there is an information -- rename *.fwc to fwx.
I can only open *.fwx and *.fwd files.
And the last post of "viewtopic.php?t=21938" - he has the same problem
Thanks for your help
georg_demmler wrote: Wed Jun 18, 2025 4:41 am Hello,
WinCC_Flexible/FlexRT_EN_RUS.exe
https://disk.yandex.ru/d/qA3JuMSnuSSXNA/WinCC_Flexible/Decode_FlexRT
https://mega.nz/file/jGoD0SLC#94ushtgkSRVSaE_QztXHWftzReMBz8jcoBhqdvPt3YQ
https://mega.nz/file/jGoD0SLC#94ushtgkSRVSaE_QztXHWftzReMBz8jcoBhqdvPt3YQ-
georg_demmler
first of all - thank you for your support - and I would say - the program work not stable and close very often by itself - most of them if you click on a name of a screen.
I test the program with different pdata-files - and only for one - it shows the address of the variables - the program was created with TIA-V14.
I don't know for what pdata-files this program works - perhaps it depends on the type of the panel, WinCCFlex-version, OS of the panel.
Thanks for your help - I finished my discussion on this topic at the moment
