[LINK]: STEP 7 V5.6 SR2 Professional version 2017/2020
xflash
Post by xflash »
2022/03 Latest:
(sdown)
STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs/document/109773842
Download Hotfix 9 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs/us/en/view/109804791
Download Hotfix 7 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs/document/109798412/
Hotfix 6 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs/us/en/view/109797830
Hotfix 5 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
 https://support.industry.siemens.com/cs/document/109783146
What has Changed Compared to Version STEP 7 V5.6 SP2?
HW Config
• Adding connections via command interface has been improved.
• The configuration of Safety modules via GSD has been improved.
• It is now once again possible to configure I devices in shared mode.
• Restricted use of scripts in the STEP 7 command interface on Windows 10
Due to thread synchronization problems when automatically saving STEP 7 user data, Visual Basic script applications can experience sporadic crashes (possibly with data loss). Therefore, the command interface is currently only partially suitable for such applications. Unpredictable errors can occur, especially with nested loop operations. It is highly recommended that you avoid such use cases and use Visual Basic scripts only with care and caution.
• As of this Hotfix: When uploading certain device configurations, the IP address was corrupted. This has now been corrected.
Programming LAD/STL/FBD blocks
• The function "Check and Update Accesses" has been improved.
History Info:
Hotfix 1 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109775201
Download Hotfix 2 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109778416
2020/05
Download Hotfix 3 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... /109779992
HW Config
• As of this Hotfix: The configuration of Safety modules via GSD has been improved.
• As of this Hotfix: It is now once again possible to configure I devices in shared mode.
https://support.industry.siemens.com/cs ... /109747981
STEP 7 V5.6 Upd4 Registrierung notwendig Download (EU) (463,0 MB)
https://support.industry.siemens.com/cs ... re-updates
https://support.industry.siemens.com/cs ... HF4_EU.zip
STEP 7 V5.6 Upd3 Registrierung notwendig Download (EU) (439,0 MB)
STEP7 Professional 2017 with STEP 7 V5.6 HF1
(sdoc) https://support.industry.siemens.com/cs ... ry-release
(sdown) https://support.industry.siemens.com/cs ... al-license
HF2 for STEP 7 V5.6
https://support.industry.siemens.com/cs ... ts-updates
It has S7-BlockPrivacy inside and FM Configuration Package (like fm-x50), CP PtP-Param in Optional Components, but no s7-scl and modbus. (boom)
So we are just waiting for Professional version (with s7-scl, s7-graph, s7-plcsim).
If some good guy know the information, please share. Thank you. (thnx)
About keys and Sim_EKB_Install - Здесь говорить о ключах
viewtopic.php?f=30&t=218
нужен экран АЛМ с установленными ключами
возможно ты попал на коллизию с ключом на Проф 5.6 - надо ставить Проф ключ для Портала 14.1 или 15.0
STEP7 v5.6 Basis license: WORKS
STEP7 v5.6 Professional license: DOES NOT WORK
STEP7 v14 Professional Combo license: DOES NOT WORK
(h)
yes... valid key for STEP7 v14.1 Professional (thnx) / для STEP7 PROFESSIONAL 2017 подходит ключ от v14.1
see New keys folder / смотрите ключ в папке Новые ключи
[/quote]
в последующих ЕКБ коллизия поправлена
Update W10 to v1703 https://www.microsoft.com/en-us/accessi ... s10upgrade
Step7 show MSVCR100.DLL error message (boom)
Install Microsoft Visual C++ Redistributable for Visual Studio 2017
https://support.microsoft.com/en-us/hel ... -downloads
Обновил W10 до v1703 https://www.microsoft.com/ru-ru/accessi ... s10upgrade
Step7 показывает ошибку отсутствия MSVCR100.DLL (boom)
Установил Распространяемый пакет Visual C++ для Visual Studio 2017
https://support.microsoft.com/ru-ru/hel ... -downloads
mustaw
Re: STEP 7 V5.6 is out, waiting for Professional version
Post by mustaw »
Thanks for the info.
Seems there is a lot which doesn't work anymore in v5.6 with Win10.
Not working with Step7 v. 5.6 + Win10:
CFC
D7-SYS
DOCPRO
MODULAR PID CONTROL TOOL
PID SELF-TUNER FBs
S7-Distributed Safety
S7-F Systems
S7-PDIAG
S7-Technology
SIMATIC iMap
SIMATIC Logon
SIMATIC Maintenance Station
SIMATIC NET SOFTWARE PACKAGE
SIMATIC Safety Matrix
SIMOTION SCOUT
SINAUT Engineering
Standard PID Control Tool
Not sure how much of the above will be needed in the future.
Looks like WinCC works with Win10 though, except WinCC flexible 2008+ if my understanding is correct.
Full list here: https://support.industry.siemens.com/cs ... y_list.pdf
but wait PCS7 v9.0 (suc)
https://www.siemens.com/global/en/home/ ... -7/v9.html
Link
Forum Community
Forum Community
Re: [LINK]: STEP 7 V5.6 Torrent
Post by Link »
Torrent
https://rutracker.org/forum/viewtopic.php?t=5411400
dirrect link for torrent client
https://mega.nz/#F!Ww9SCCZQ!6NhIu768fib7w2DUFu0wPw
Step7_v5.6_ISO_upd_rutracker.org.t5411400.zip
*********** wait SP1 ****************
very slow on Windows 10 (h) and with (boom)
xf2000
Re: [LINK]: STEP 7 V5.6 is out, waiting for Professional ver
Post by xf2000 »
Update
Forum Community
Forum Community
Post by Update »
Torrent Updated = add S7-SCL v5.6 + S7-GRAPH v5.6 + PLCSIM v5.4 SP8
Please redownload to same folder
Раздача обновлена - добавлены S7-SCL v5.6 + S7-GRAPH v5.6 + PLCSIM v5.4 SP8
перекачайте в ту же папку
direct link for torrent client https://mega.nz/#F!Ww9SCCZQ!6NhIu768fib7w2DUFu0wPw
pisoj wrote:Simulations wont work for me.
Windows 10 x64 work
xf2000
Post by xf2000 »
STEP7 Professional 2017 with Hotfix 1 for STEP 7 V5.6
What has Changed hotfix 1 for STEP 7 V5.6 Compared to Version STEP 7 V5.6?
Installation of hotfix 1 for STEP 7 V5.6
As of this hotfix: If after installing a hotfix 1 for STEP 7 V5.6 the original installation is changed with "Change program" or "Repair program" the hotfix needs to be installed again.
HW Config
Ab diesem Hotfix: In a configuration that uses the function "Use different method to obtain IP address" there is no longer a warning relating to the NTP server address and another subnet.
SIMATIC Manager
As of this hotfix: The display of the object size of objects larger than 2 GB has been improved.
Report System Errors
As of this hotfix: A battery fault is also displayed for a CPU if this is operated in a non-redundant configuration.
Link
Forum Community
Forum Community
Re: [LINK]: STEP 7 V5.6 Professional version 2017
Post by Link »
torrent update
SIEMENS_SIMATIC_STEP7_v5.6_Professional_2017_rutracker_torrent.zip
Re: [LINK]: STEP 7 V5.6 HF1 Professional version 2017
maybe I am the first, who informs you that the following licenses does not work with the
newly available STEP7 PROFESSIONAL 2017 installation media which installs Step7 v5.6 HF1.
Download the new installation ISO:
https://support.industry.siemens.com/cs ... 109749428/
(h)
KPPNST
Post by KPPNST »
van8x10 wrote:STEP 7 2017 Pro (V5.6) runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
It runs and works on Windows 10 Enterprise RUS v1703 x64 (15063.540) (i7-4710HQ + 8Gb RAM + SSD 256G) very well and fast.
van8x10
Post by van8x10 »
van8x10 wrote: Sat Aug 12, 2017 7:36 am STEP 7 2017 Pro (V5.6) runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
Yeah, I've reset my laptop and re-installed the software, and now it works well!
MILSANT2016
Post by MILSANT2016 »
friends
Download the software from Step 7 v 5.6 indicated on the page.
When I want to install everything, it is going well until you inform me that Step 7 v5.6 can not be installed because the computer has installed step 7 V5.6 HF1 WHAT IS NOT TRUE WHAT HAPPENS AND PLEASE IF SOMEONE CAN HELP ME
THANK YOU. (oo) (h)
MILSANT2016
Dear
A while ago I had a problem with the EKB ESPECIALLY THOSE OF 2017 _8.
I DO ALL THE OPERATIONS THROW THEM IN THE FOLDER
AX NF ZZ BUT DO NOT TAKE THE PROGRAMS.
MY OPERATIVE SYSTEM IS WINDOWS 10 PRO OF 64 BITS.
I INSTALL ANY SIEMENS PROGRAM AND DO NOT ACTIVATE IT WHAT CAN IT BE? NEITHER DOES THE AUTOMATION MANAGER CONNECT THE EKB PROGRAM WHAT CAN I DO? THANK MUCH.
roberto_battistella
Post by roberto_battistella »
you can download hf3 only after opening a ticket to the support request (or I can pass it through we transfer)
xflash
Post by xflash »
roberto_battistella wrote:you can download hf3 only after opening a ticket to the support request (or I can pass it through we transfer)
Please do that or upload to mega. Thank you a lot.
xflash
Post by xflash »
ilmisu wrote:any feedback to install distributed safety onto step 7 5.6?
It works on me, but I did not use it in real system yet.
Update
Forum Community
Forum Community
Post by Update »
Update
Forum Community
Forum Community
Re: [LINK]: STEP 7 V5.6 HF3 Professional version 2017
Post by Update »
boldive
Re: [LINK]: STEP 7 V5.6 HF4 Professional version 2017
Post by boldive »
Have installed HF4. There is NO performance changes. v.5.6 is very slow. Most of the time I am using v.5.5
xflash
Post by xflash »
boldive wrote:Have installed HF4. There is NO performance changes. v.5.6 is very slow. Most of the time I am using v.5.5
Are you using Windows 10 or Win7 ?
Laptop core i5 memory 6 GB normal hard - Step7v5.6HF4 and winCCflexible2008HF5 work - fly.
MEFinc
Post by MEFinc »
Hotfix 5 download for STEP 7 V5.6 and STEP 7 Professional 2017
(sdown) https://support.industry.siemens.com/cs ... ional-2017
boldive
Post by boldive »
xflash wrote: Are you using Windows 10 or Win7 ?
Win7 Enterprise on VMWare.
Same virtual machine works mach faster with v.5.5
So, this is not an operating system, this is the v5.6 itself.
xflash
Post by xflash »
Try step 7 5.6 hf5.
Link
Forum Community
Forum Community
Re: [LINK]: STEP 7 V5.6 SR1 Professional version 2017/2018
Post by Link »
Update
Forum Community
Forum Community
Post by Update »
Sim_EKB_Install Folder
Torrent https://rutracker.org/forum/viewtopic.php?t=5572061
Sim_EKB_Install_2018_11_14 for WinCC v7.5
https://mega.nz/#!3CR0jCZZ!1qAYwkecwNAw ... JlRbA_FdGs
Umencho
Post by Umencho »
ilmisu wrote: Mon Feb 05, 2018 1:13 pm any feedback to install distributed safety onto step 7 5.6?
Go with Update 2 for SIMATIC S7 Distributed Safety V5.4 SP5, especially if WIN10 is the OS.
https://support.industry.siemens.com/cs ... y-v5-4-sp5
As a registered customer, you can download Update 2 for SIMATIC S7 Distributed Safety SP5.
Update 2 is for
upgrading SIMATIC S7 Distributed Safety V5.4 SP5
New installation = Full version
Use as 14-day trial version for test purposes or Sim_EKB
MEFinc
Post by MEFinc »
(sdown) Hotfix 3 STEP 7 V5.6 SP1 / STEP 7 Professional 2017 SR1
What has Changed Compared to Version STEP 7 V5.6 SP1? wrote: HW Config
· The installation of HSPs is now possible using the command line call via the HSP installer. You can find more information in the help on configuring the hardware in topic "Installing HW Updated via the Command Line".
· The operation of a DP/FF-Link downstream from an IE/PB-Link V3.1 is now possible.
· As of this Hotfix: A configuration in RUN is now once again possible for specific configurations that were downloaded to the CPU with STEP 7 V5.5 SP4 HF9.
NetPro
· The output of warnings during compilation in NetPro has been improved.
Report System Error
· Generating 'Report System Error' has been improved.
Umencho
Post by Umencho »
Togomi
Post by Togomi »
I have to install Step 7 on W10 and I've found Step 7 v5.6 SP1 and Step 7 Professional 2017 SR1.
I checked that Professional includes PLCSIM, S7-GRAPH...
Which one should I install?
v5.6 SP1 requires to install PLCSIM and S7-GRAPH after, doesn't it?
And I've found HF3 and HF5.
Sould I install both or HF5 is enough?
Should I install with v5.6 SP1 and Professional 2017 SR1? Do both require the update?
The most recent EKB I have is from November 2018. Is there another one more recent?
"STEP 7 Professional" is TradeMark of install package = STEP 7 V5.* + PLCSIM + S7-SCL + S7-Graph
Hotfix N+1 include Hotfix N = see size
https://new.siemens.com/global/en/produ ... er-sw.html
Togomi
Post by Togomi »
Thanks.
Do you know if HF3 or HF5 are important?
https://support.industry.siemens.com/cs ... /109767446
I had v5.6 in W10 two years ago and Step 7 had problems that required HF's to solve them.
I don't know how Step 7 v5.6 SP1 works on W10 recently.
Greets
Umencho
Post by Umencho »
Step 7 5.6 SP1 is working on WIN10.
Check the projects on which you will work and based on that select the software they will need.
h4rdw4re
Re: [LINK]: STEP 7 V5.6 SR1 HF5 Professional version 2017/2018
Post by h4rdw4re »
(sdown) Download Hotfix 5 STEP 7 V5.6 SP1 / STEP 7 Professional 2017 SR1
https://support.industry.siemens.com/cs ... 0&lc=en-US
Togomi
Post by Togomi »
Step 7 Professional 2017 working on W10.
Howi wrote: Thu Sep 19, 2019 9:48 amdo we have pdiag 5.6 key?
Update
Forum Community
Forum Community
[LINK]: STEP 7 V5.6 SR2 HF1 Professional 2017/2020
Post by Update »
https://support.industry.siemens.com/cs ... /109773842
  • What has Changed Compared to Version STEP 7 V5.6 SP2?
    HW Config
    • As of this Hotfix: Adding connections via command interface has been improved.
    • As of this Hotfix: The function "Check and Update Accesses" has been improved.
shadow06
Re: [LINK]: STEP 7 V5.6 SR2 Professional version 2017/2018
Post by shadow06 »
mega or torrent link please (dlink)
misa1515
Post by misa1515 »
xflash
Re: [LINK]: STEP 7 V5.6 SR2 Professional version 2017/2020
Post by xflash »
https://support.industry.siemens.com/cs/document/109779992
2020/05
The site admin have helped update the post. please update.
jeffinko
Post by jeffinko »
Reupload : STEP7_PROFESSIONAL_2017_SR2.iso
https://ulozto.sk/file/5JA2aZQccTBX/ste ... 17-sr2-iso
Update
Forum Community
Forum Community
Post by Update »
(sdown) https://support.industry.siemens.com/cs ... /109783146
HW Config
enea
Post by enea »
Hi everybody i just installed on win10 and i have problem with license ,during EKB install it says :(Access violation at address 0040B7CC in module'Sim_EKB_Install_2020_10_10.exe'.Read of address EEF2E0DE.)
Thankyou!
EKB file is System Hidden in System Hidden folder C:\AX NF ZZ = for write EKB need Run as Admin
ЕКБ файлы Скрытые Системные в Скрытой Системной папке C:\AX NF ZZ = для их записи надо запускать с полномочиями Администратора
jpm_oliveira
Post by jpm_oliveira »
I'm try to install license for TIA portal 16 Upd3 with EKB_Install_2020_04_17 (running as administrator on Win10) but it show me the follow error message:
"CryptAcquireContext MS_DEF_PROV Error of containger opening: NTE_BAD_KEYSET"
and a second one:
"CryptAcquireContext PROV_RSA_FULL Error of containger opening: unknown error"
Someone can help me on this matter?
pisoj
Post by pisoj »
Anyone can provide with torrent or mega for Hotfix 1 of Step 7 Professional 2017 SR2???
Thanks!
roberto_battistella
[LINK]: Hotfix 5 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
29/10/2020
(sdown) Hotfix 5 STEP 7 V5.6 SP2 / STEP 7 Professional 2017 SR2
https://support.industry.siemens.com/cs ... n&lc=it-IT
Felipe_Mendonca
Post by Felipe_Mendonca »
Hi, I have some question
Need I to install all hot fixes to Step 7 v5.6? or Can I to install just the latest?
