It is currently Mon Jul 16, 2018 3:28 pm
Post new topic Reply to topic  [ 31 posts ]
PostPosted: Fri Jun 02, 2017 9:32 am
https://support.industry.siemens.com/cs/ww/en/view/109747981
STEP 7 V5.6 Upd4 Registrierung notwendig Download (EU) (463,0 MB)
https://support.industry.siemens.com/cs/document/109756832/simatic-pcs-7-v9-0-sp1-software-updates
https://support.industry.siemens.com/cs/attachments/109756832/SIMATIC_PCS7_V9_0_SP1_ES_OS-STEP7_V56_HF4_EU.zip
https://support.industry.siemens.com/cs/document/109757236/simatic-pcs-7-v9-0-software-updates
STEP 7 V5.6 Upd3 Registrierung notwendig Download (EU) (439,0 MB)
STEP7 Professional 2017 with STEP 7 V5.6 HF1
(sdoc) https://support.industry.siemens.com/cs/document/109749362/simatic-step-7-professional-2017-sales-and-delivery-release
(sdown) https://support.industry.siemens.com/cs/document/109749428/where-do-you-procure-the-current-software-for-step-7-professional-2017-incl-trial-license
HF2 for STEP 7 V5.6
https://support.industry.siemens.com/cs/document/109752814/simatic-pcs-7-es-os-system-components-updates
It has S7-BlockPrivacy inside and FM Configuration Package (like fm-x50), CP PtP-Param in Optional Components, but no s7-scl and modbus. (boom)
So we are just waiting for Professional version (with s7-scl, s7-graph, s7-plcsim).
If some good guy know the information, please share. Thank you. (thnx)
About keys and Sim_EKB_Install - Здесь говорить о ключах
viewtopic.php?f=30&t=218
нужен экран АЛМ с установленными ключами
возможно ты попал на коллизию с ключом на Проф 5.6 - надо ставить Проф ключ для Портала 14.1 или 15.0
STEP7 v5.6 Basis license: WORKS
STEP7 v5.6 Professional license: DOES NOT WORK
STEP7 v14 Professional Combo license: DOES NOT WORK
(h)
yes... valid key for STEP7 v14.1 Professional (thnx) / для STEP7 PROFESSIONAL 2017 подходит ключ от v14.1
see New keys folder / смотрите ключ в папке Новые ключи
[/quote]
в последующих ЕКБ коллизия поправлена
Update W10 to v1703 https://www.microsoft.com/en-us/accessibility/windows10upgrade
Step7 show MSVCR100.DLL error message (boom)
Install Microsoft Visual C++ Redistributable for Visual Studio 2017
https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
Обновил W10 до v1703 https://www.microsoft.com/ru-ru/accessibility/windows10upgrade
Step7 показывает ошибку отсутствия MSVCR100.DLL (boom)
Установил Распространяемый пакет Visual C++ для Visual Studio 2017
https://support.microsoft.com/ru-ru/help/2977003/the-latest-supported-visual-c-downloads
PostPosted: Fri Jun 02, 2017 3:59 pm
Thanks for the info.
Seems there is a lot which doesn't work anymore in v5.6 with Win10.
Not working with Step7 v. 5.6 + Win10:
CFC
D7-SYS
DOCPRO
MODULAR PID CONTROL TOOL
PID SELF-TUNER FBs
S7-Distributed Safety
S7-F Systems
S7-PDIAG
S7-Technology
SIMATIC iMap
SIMATIC Logon
SIMATIC Maintenance Station
SIMATIC NET SOFTWARE PACKAGE
SIMATIC Safety Matrix
SIMOTION SCOUT
SINAUT Engineering
Standard PID Control Tool
Not sure how much of the above will be needed in the future.
Looks like WinCC works with Win10 though, except WinCC flexible 2008+ if my understanding is correct.
Full list here: https://support.industry.siemens.com/cs/attachments/109747706/STEP_7_V56_-_Compatibility_list.pdf
but wait PCS7 v9.0 (suc)
https://www.siemens.com/global/en/home/products/automation/distributed-control-system/simatic-pcs-7/v9.html
PostPosted: Sat Jun 03, 2017 11:46 am
Torrent
https://rutracker.org/forum/viewtopic.php?t=5411400
dirrect link for torrent client
Step7_v5.6_ISO_upd_rutracker.org.t5411400.zip
*********** wait SP1 ****************
very slow on Windows 10 (h) and with (boom)
PostPosted: Wed Jun 07, 2017 2:40 pm
SIMATIC S7-SCL V5.6
https://support.industry.siemens.com/cs/ww/en/view/109748118
SIMATIC S7-Graph V5.6
https://support.industry.siemens.com/cs/ww/en/view/109748125
SIMATIC S7-PLCSIM V5.4 SP8
https://support.industry.siemens.com/cs/document/109750064
PostPosted: Fri Jun 09, 2017 4:26 am
STEP 7 V5.6 runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
PostPosted: Fri Jun 09, 2017 10:40 am
Setting the PG/PC Interface is very slow (not responding), and there is no driver for USB PC Adapter!
PostPosted: Fri Jun 09, 2017 1:07 pm
Torrent Updated = add S7-SCL v5.6 + S7-GRAPH v5.6 + PLCSIM v5.4 SP8
Please redownload to same folder
Раздача обновлена - добавлены S7-SCL v5.6 + S7-GRAPH v5.6 + PLCSIM v5.4 SP8
перекачайте в ту же папку
direct link for torrent client https://mega.nz/#F!Ww9SCCZQ!6NhIu768fib7w2DUFu0wPw
PostPosted: Sun Jun 18, 2017 6:05 am
Anyway your are guy always make perfect professional works! Thanks! (gpost)
PostPosted: Mon Jul 24, 2017 9:29 pm
Simulations wont work for me.
PostPosted: Tue Jul 25, 2017 9:13 pm
Windows 10 x64 work
PostPosted: Tue Jul 25, 2017 9:16 pm
PostPosted: Thu Aug 10, 2017 4:16 am
Only things we can do is to wait. There is a long way that step7 5.6 could be used on site.
PostPosted: Fri Aug 11, 2017 1:41 pm
STEP7 Professional 2017 with Hotfix 1 for STEP 7 V5.6
What has Changed hotfix 1 for STEP 7 V5.6 Compared to Version STEP 7 V5.6?
Installation of hotfix 1 for STEP 7 V5.6
As of this hotfix: If after installing a hotfix 1 for STEP 7 V5.6 the original installation is changed with "Change program" or "Repair program" the hotfix needs to be installed again.
HW Config
Ab diesem Hotfix: In a configuration that uses the function "Use different method to obtain IP address" there is no longer a warning relating to the NTP server address and another subnet.
SIMATIC Manager
As of this hotfix: The display of the object size of objects larger than 2 GB has been improved.
Report System Errors
As of this hotfix: A battery fault is also displayed for a CPU if this is operated in a non-redundant configuration.
PostPosted: Fri Aug 11, 2017 2:37 pm
torrent update
SIEMENS_SIMATIC_STEP7_v5.6_Professional_2017_rutracker_torrent.zip
PostPosted: Sat Aug 12, 2017 10:36 am
STEP 7 2017 Pro (V5.6) runs very slowly on Windows 10 Pro 64bit (h) ! (version 1703, Build 15063.332)
PostPosted: Mon Aug 14, 2017 12:05 am
maybe I am the first, who informs you that the following licenses does not work with the
newly available STEP7 PROFESSIONAL 2017 installation media which installs Step7 v5.6 HF1.
Download the new installation ISO:
https://support.industry.siemens.com/cs ... 109749428/
(h)
PostPosted: Thu Aug 31, 2017 11:56 am
It runs and works on Windows 10 Enterprise RUS v1703 x64 (15063.540) (i7-4710HQ + 8Gb RAM + SSD 256G) very well and fast.
PostPosted: Mon Sep 11, 2017 5:54 am
Yeah, I've reset my laptop and re-installed the software, and now it works well!
PostPosted: Sun Nov 26, 2017 12:16 am
friends
Download the software from Step 7 v 5.6 indicated on the page.
When I want to install everything, it is going well until you inform me that Step 7 v5.6 can not be installed because the computer has installed step 7 V5.6 HF1 WHAT IS NOT TRUE WHAT HAPPENS AND PLEASE IF SOMEONE CAN HELP ME
THANK YOU. (oo) (h)
PostPosted: Mon Dec 04, 2017 2:09 am
Dear
A while ago I had a problem with the EKB ESPECIALLY THOSE OF 2017 _8.
I DO ALL THE OPERATIONS THROW THEM IN THE FOLDER
AX NF ZZ BUT DO NOT TAKE THE PROGRAMS.
MY OPERATIVE SYSTEM IS WINDOWS 10 PRO OF 64 BITS.
I INSTALL ANY SIEMENS PROGRAM AND DO NOT ACTIVATE IT WHAT CAN IT BE? NEITHER DOES THE AUTOMATION MANAGER CONNECT THE EKB PROGRAM WHAT CAN I DO? THANK MUCH.
PostPosted: Sat Dec 16, 2017 11:43 am
I'm searching for the Hotfix 3 of STEP7 V5.6.
Thanks in advance.
PostPosted: Sun Jan 07, 2018 12:29 am
you can download hf3 only after opening a ticket to the support request (or I can pass it through we transfer)
PostPosted: Sun Jan 21, 2018 10:52 am
Please do that or upload to mega. Thank you a lot.
PostPosted: Mon Feb 05, 2018 4:13 pm
any feedback to install distributed safety onto step 7 5.6?
PostPosted: Fri Feb 09, 2018 1:10 am
It works on me, but I did not use it in real system yet.
PostPosted: Mon Feb 12, 2018 9:31 pm
HF2 for STEP 7 V5.6
PostPosted: Thu Feb 15, 2018 1:15 pm
Hi, can you write what are new features in this version, something something besides compatibility with Windows 10?
PostPosted: Mon Apr 30, 2018 12:21 am
PostPosted: Sat May 19, 2018 7:41 pm
Have installed HF4. There is NO performance changes. v.5.6 is very slow. Most of the time I am using v.5.5
PostPosted: Thu May 31, 2018 12:12 pm
Are you using Windows 10 or Win7 ?
PostPosted: Thu May 31, 2018 12:37 pm
Laptop core i5 memory 6 GB normal hard - Step7v5.6HF4 and winCCflexible2008HF5 work - fly.
Users browsing this forum: Google [Bot] and 34 guests
