[About]: Step7 v5.5 Block Privacy v1.0
ppp
Post by ppp »
In new version 5.5 not visible password under stars .
Schtiel
Re: [INFO]: Simatic RoadMap - whats new in Step7 v5.5, PCS7.
Post by Schtiel »
There is a new feature in Step7 v. 5.5 called S7 Block Privacy (installation is available at CD_2\Optional Components\S7 Block Privacy).
As I understand, it is an alternative to obsolete "Know-How protection". The question is if it's possible to open blocks that are protected with S7 Block Privacy without knowledge of a password. :?:
Update
Forum Community
Forum Community
Post by Update »
Step7 V5.5 new S7-Block Privacy
http://www.youtube.com/watch?v=XW5hcWRdB7Q
The program-code will be encrypted with 128 Bit on the PG, encoded transmitted and decrypted on the controller.
BlockPrivacy_README wrote:SIMATIC S7 Block Privacy V1.0
2.1 General Notes
· The call for the S7 Block Privacy application is integrated in the SIMATIC Manager. It is always called in the shortcut menu of the block folder (menu command "Block Privacy..."), this means that the STEP 7 project and the S7 program are specified for the called S7 Block Privacy instance. If an S7 Block Privacy instance exists when you call S7 Block Privacy for a different S7 program, the new parameters (STEP 7 project and S7 program) are passed to the running program.
· S7 Block Privacy supports function blocks(FB) and functions (FC).
· The CPU must have at least the following version:
o CPU 3xx: firmware version V3.2 or higher
o CPU 4xx: firmware version V6.0 or higher
· Following encryption, the encrypted blocks are available in the databases of a STEP 7 project.
· Encrypted blocks cannot be processed with earlier versions STEP 7 (call, instantiation etc.).
· The S7 Block Privacy application works only in conjunction with the SIMATIC Manager. Exiting the SIMATIC Manager also exits S7 Block Privacy.
· Encrypted blocks cannot be simulated with S7-PLCSIM.
Russian wrote:Новый метод защиты функциональных блоков (FB) и функций (FC) в Step7 V5.5.
Программный код шифруется 128 битным ключом в программаторе, в защифрованном виде передаётся в контроллер, где и дешифруется.
Данный метод защиты блоков применим только к новым процессорам s7-300 V3.2 и s7-400 V6.0.
Защищённые данным методом блоки нельзя открыть в предыдущих версиях Степ7.
Защищённые данным методом блоки нельзя симулировать в S7-PLCSIM.
Mrc2
Re: [About]: Step7 v5.5 Block Privacy v1.0
Post by Mrc2 »
and WinAcRTX...?
..................... (tyou)
ilndep wrote:I install Step7 V5.5 and after new S7-Block Privacy but when I lunch S7-Block Privacy the same program close immediatly. Why ?
The installation of Step 7 V5.5 overwrite Step7 V5.4
In my comp is Ok.
ilndep
Post by ilndep »
Hi CoMod,
to run S7-Block Privacy I must close all files of antivirus by Task Manager Windows.
What is the connection with antivirus ?
With KIS2011 it work.
See blocked program and unblock S7-Block Privacy :)
ilndep
Post by ilndep »
The program is not blocked but it is closed in automatic !!!
I don't understand why ?
Send :?: to F-Secure support.
When Kaspersky hurt (boom) , I'll switch off (warn)
Mrc2
Post by Mrc2 »
i have testet v5.5,but i cant found the block privacy button,
im serching on my comp for the s7blpapx.exe but not found,
why that...? (wow)
Install manually from
Step7 V5.5\CD_2\Optional Components\S7 Block Privacy
ppp
Post by ppp »
Т.е. в контроллере на флешке программа лежит уже без ключа?
И что тогда мешает сдернуть ее сименсовским программатором или картридером?
greg2008
Post by greg2008 »
На флешке прога лежит зашифрованная. При считывании контроллер ее расшифровывает. Если сумеете ее сдернуть расшифрованную из памяти, то Вам повезло. ПО для дешифровки встроено в операционку. Если у Вас проц не подходящей версии, то исполнение защищенной программы Вам не светит.
ppp
Post by ppp »
Интересно а как проц ее дешифрует без пароля?
Или пароль тоже бросается на флэш?
Надо разбирать S7BLPAPX.EXE в http://rutracker.org/forum/viewtopic.php?t=2537609
greg2008
Post by greg2008 »
ppp wrote:Интересно а как проц ее дешифрует без пароля?
Читайте про RSA-кодирование
AndreyUA
Post by AndreyUA »
У меня блоки помеченные encrypt сливаются с контроллера, т.е. в контроллере они не зашифрованы? А brock privacy устанавливаться не хочет, постоянно требует перезагрузить компьютер.
vlad2006gr
Post by vlad2006gr »
S7BLPAPX.EXE это только оболочка. Используется виндошная CryptoAPI экспортируемая с Advapi32.dll, Crypt32.dll и Cryptsp.dll. Тут довольно сложно "разобрать", т.к. нужно работать на уровне ядра виндовс. Шифруется файл на карте памяти, или нет, точно не известно. Само шифрование в ЦПУ 300 или 400 затруднительно, т.к. требует значительных ресурсов процессора. Возможно только реализация на уровне железа, с аппаратно реализованными алгоритмами, как в чип картах. Все это увеличивает избыточнось, снижая надежность. Для решения возможности обойти защиту, необходим образ скаченный с карты с установленным Block Privacy v1.0, образ той-же программы без защиты, и сама программа. Достаточно программы с пару блоками, не пустыми.
mostagear
Post by mostagear »
Please help for. S7 program plc block privacy password can you help for the password ,, (sos)
https://drive.google.com/file/d/0B1R4cD ... sp=sharing
(tyou)
duongvuquy
Post by duongvuquy »
http://www.mediafire.com/download/157c0 ... 1510cm.zip
I have a project as above link, But I can't find password of safety FC.
Please help me to find it.
Thanks and best regards,
eljaml
Post by eljaml »
pls i have some red blocks with password for CPU s7-319 , any help to unlock it (nuser)
any help pls send it to me by email -****
StudAsu
Post by StudAsu »
Необходима помощь в открытии Block Privacy, наладчик который производил ПНР уволился, и ушел не совсем красиво, проект закрыт а пароль он хочет продать, руководство из принципа не идет на контакт с ним, со словами лучше заплатить другому. А я теперь должен что то сделать с этим, нахожусь меж двух огней! есть какие то варианты???
На данный момент нет способа открыть закодированное по Block Privacy.
Как вариант можно выложить копии экранов Симатик Менеджера с перечнем функций
типа
выложить на файлообменник слитую программу или образ карты ММС... может там на самом деле KnowHow.
На мудака подать в суд... это если он работал штатно или по бумажному договору - неправомочное... вредительство и т.д.
CwcPLC
Post by CwcPLC »
Hello everyone
After the function block has been encrpted, how could I unlock it?
Or is there any way to unlock the red block
thank you
hanjinxing
Post by hanjinxing »
(no)
(no) There is no way at present
SHKODRAN
Post by SHKODRAN »
something interesting.
Team-Uare has already decrypted it.
replace S7BLPAX.EXE by patched_S7BLPAX.EXE
ppp
Post by ppp »
Very probably on a fake. Here if after that also the block was opened in the editor. I when investigated protection too was got "protection removals", but the block really did not open
roberto_battistella
Post by roberto_battistella »
Hello. how can you download this file. the link does not work. Can anyone help me ? thank you very much (oo)
SHKODRAN
Post by SHKODRAN »
ppp wrote: Thu Jan 09, 2020 9:17 pm Very probably on a fake. Here if after that also the block was opened in the editor. I when investigated protection too was got "protection removals", but the block really did not open
are you sure ?
I have tried it and I guarantee that it works properly.
Do not forget that if you have not succeeded, nobody can succeed!
roberto_battistella
Hello. sorry SHKODRAN but I can't download the file; can you upload the right link or tell me how to download the file? thank you very much
SHKODRAN
Post by SHKODRAN »
Link is working properly.
Spoiler
Show
Regards.
and where is the file "patched_S7BLPAX.EXE" itself?
SHKODRAN
Post by SHKODRAN »
Right now in the hands of those who patched it.
It will not be public, as it should be.
ppp
Post by ppp »
Maybe I am mistaken, but in video there is no opening in the editor of blocks.
This video = fake
roberto_battistella
Hi SHKODRAN. Sorry, but you don't see anything in the video and I can't find any download links. I would like to understand if you want to share the info with us all. Give us a clear answer. Thank you.
dj1178
Post by dj1178 »
SHKODRAN wrote: Fri Jan 10, 2020 10:54 am Hi,
Dear Shkodran
THE VIDEO is OK and it's cracked
where is the file?
roberto_battistella
Hello.
I also associate myself with what was said by dj1178; in my previous post I expressed myself badly. The video is correct and you can see how the procedure works. Unfortunately, you still can't figure out where to find the cracked file. Thanks for the info you want to share. Hello.
(usearch) :haha:
SHKODRAN
Post by SHKODRAN »
The file will not be public.
When it is fully functional in every aspect, I will tell you where to request to unlock.
roberto_battistella
Hello. have there been any developments on this program? thank you very much.
roberto_battistella
hi everyone, have there been any developments? thank you very much (oo)
PeterTan
Post by PeterTan »
Hello.
thank you very much
You have send me file unblock FC FB step 7 "privacy" ?
email: peter.dinhtan@gmail.com
Thank you
Toms
Post by Toms »
See hope! Start installing OD decompiler software challenge!
roberto_battistella
74/5000
Hello. are there any developments or updates for this software? thank you very much. (boom)
roberto_battistella
Hi everyone. no development yet? thank you very much.
fbarbosa
Post by fbarbosa »
Hi all.
That is really some nice work there. Congrats on the accomplishment!
Of course that, if this can be released, it would be great.
roberto_battistella
as yet there have been no communications. it is not clear if the softre is complete and if it can be used. does anyone know something? thank you so much.
Umencho
Post by Umencho »
Someone to update the topic?
roberto_battistella
hi, does anyone have any updates on this? thank you
SHKODRAN
Post by SHKODRAN »
I'm sorry, never can be public.
Regards.
