ppp
Post
by ppp » Fri Aug 27, 2010 7:25 am
In new version 5.5 not visible password under stars .
Schtiel
Post
by Schtiel » Fri Aug 27, 2010 8:17 am
There is a new feature in Step7 v. 5.5 called S7 Block Privacy (installation is available at CD_2\Optional Components\S7 Block Privacy).
As I understand, it is an alternative to obsolete "Know-How protection". The question is if it's possible to open blocks that are protected with S7 Block Privacy without knowledge of a password.
Update
- Forum Community
Post
by Update » Fri Aug 27, 2010 7:35 pm
Step7 V5.5 new S7-Block Privacy
http://www.youtube.com/watch?v=XW5hcWRdB7Q
The program-code will be encrypted with 128 Bit on the PG, encoded transmitted and decrypted on the controller.
BlockPrivacy_README wrote:SIMATIC S7 Block Privacy V1.0
2.1 General Notes
· The call for the S7 Block Privacy application is integrated in the SIMATIC Manager. It is always called in the shortcut menu of the block folder (menu command "Block Privacy..."), this means that the STEP 7 project and the S7 program are specified for the called S7 Block Privacy instance. If an S7 Block Privacy instance exists when you call S7 Block Privacy for a different S7 program, the new parameters (STEP 7 project and S7 program) are passed to the running program.
· S7 Block Privacy supports function blocks(FB) and functions (FC).
· The CPU must have at least the following version:
o CPU 3xx: firmware version V3.2 or higher
o CPU 4xx: firmware version V6.0 or higher
· Following encryption, the encrypted blocks are available in the databases of a STEP 7 project.
· Encrypted blocks cannot be processed with earlier versions STEP 7 (call, instantiation etc.).
· The S7 Block Privacy application works only in conjunction with the SIMATIC Manager. Exiting the SIMATIC Manager also exits S7 Block Privacy.
· Encrypted blocks cannot be simulated with S7-PLCSIM.
Russian wrote:Новый метод защиты функциональных блоков (FB) и функций (FC) в Step7 V5.5.
Программный код шифруется 128 битным ключом в программаторе, в защифрованном виде передаётся в контроллер, где и дешифруется.
Данный метод защиты блоков применим только к новым процессорам s7-300 V3.2 и s7-400 V6.0.
Защищённые данным методом блоки нельзя открыть в предыдущих версиях Степ7.
Защищённые данным методом блоки нельзя симулировать в S7-PLCSIM.
Mrc2
Post
by Mrc2 » Wed Sep 01, 2010 3:56 pm
and WinAcRTX...?
Post
by CoMod » Thu Sep 02, 2010 8:18 pm
ilndep wrote:I install Step7 V5.5 and after new S7-Block Privacy but when I lunch S7-Block Privacy the same program close immediatly. Why ?
The installation of Step 7 V5.5 overwrite Step7 V5.4
In my comp is Ok.
ilndep
Post
by ilndep » Fri Sep 03, 2010 4:50 pm
Hi CoMod,
to run S7-Block Privacy I must close all files of antivirus by Task Manager Windows.
What is the connection with antivirus ?
Post
by CoMod » Fri Sep 03, 2010 5:03 pm
ilndep wrote:to run S7-Block Privacy I must close all files of antivirus by Task Manager Windows.
Where is connection with antivirus ?
With KIS2011 it work.
See blocked program and unblock S7-Block Privacy
ilndep
Post
by ilndep » Fri Sep 03, 2010 6:32 pm
The program is not blocked but it is closed in automatic !!!
I don't understand why ?
Post
by CoMod » Fri Sep 03, 2010 6:55 pm
ilndep wrote:The program is not blocked but it is closed in automatic !!!
Send
to F-Secure support.
When Kaspersky hurt
, I'll switch off
Mrc2
Post
by Mrc2 » Sun Sep 12, 2010 10:24 pm
i have testet v5.5,but i cant found the block privacy button,
im serching on my comp for the s7blpapx.exe but not found,
why that...?
Post
by CoMod » Mon Sep 13, 2010 5:08 am
Install manually from
Step7 V5.5\CD_2\Optional Components\S7 Block Privacy
ppp
Post
by ppp » Mon Sep 13, 2010 12:56 pm
Т.е. в контроллере на флешке программа лежит уже без ключа?
И что тогда мешает сдернуть ее сименсовским программатором или картридером?
greg2008
Post
by greg2008 » Mon Sep 13, 2010 3:43 pm
На флешке прога лежит зашифрованная. При считывании контроллер ее расшифровывает. Если сумеете ее сдернуть расшифрованную из памяти, то Вам повезло. ПО для дешифровки встроено в операционку. Если у Вас проц не подходящей версии, то исполнение защищенной программы Вам не светит.
ppp
Post
by ppp » Tue Sep 14, 2010 4:22 am
Интересно а как проц ее дешифрует без пароля?
Или пароль тоже бросается на флэш?
greg2008
Post
by greg2008 » Fri Sep 17, 2010 4:44 pm
ppp wrote:Интересно а как проц ее дешифрует без пароля?
Читайте про RSA-кодирование
AndreyUA
Post
by AndreyUA » Tue Jan 05, 2016 1:53 pm
У меня блоки помеченные encrypt сливаются с контроллера, т.е. в контроллере они не зашифрованы? А brock privacy устанавливаться не хочет, постоянно требует перезагрузить компьютер.
Info
- Faq & Info
Post
by Info » Tue Jan 05, 2016 4:37 pm
vlad2006gr
Post
by vlad2006gr » Wed Jan 06, 2016 9:20 am
S7BLPAPX.EXE это только оболочка. Используется виндошная CryptoAPI экспортируемая с Advapi32.dll, Crypt32.dll и Cryptsp.dll. Тут довольно сложно "разобрать", т.к. нужно работать на уровне ядра виндовс. Шифруется файл на карте памяти, или нет, точно не известно. Само шифрование в ЦПУ 300 или 400 затруднительно, т.к. требует значительных ресурсов процессора. Возможно только реализация на уровне железа, с аппаратно реализованными алгоритмами, как в чип картах. Все это увеличивает избыточнось, снижая надежность. Для решения возможности обойти защиту, необходим образ скаченный с карты с установленным Block Privacy v1.0, образ той-же программы без защиты, и сама программа. Достаточно программы с пару блоками, не пустыми.
eljaml
Post
by eljaml » Sun Aug 14, 2016 9:45 am
pls i have some red blocks with password for CPU s7-319 , any help to unlock it
any help pls send it to me by email -****
StudAsu
Post
by StudAsu » Tue Dec 27, 2016 6:48 am
Need help in opening the FC
Post
by CoMod » Tue Dec 27, 2016 7:13 am
StudAsu wrote:Need help in opening the FC
============== ADMIN ============
email will be deleted
пиши что надо со всеми подробностями
StudAsu
Post
by StudAsu » Tue Dec 27, 2016 7:23 am
Необходима помощь в открытии Block Privacy, наладчик который производил ПНР уволился, и ушел не совсем красиво, проект закрыт а пароль он хочет продать, руководство из принципа не идет на контакт с ним, со словами лучше заплатить другому. А я теперь должен что то сделать с этим, нахожусь меж двух огней! есть какие то варианты???
Post
by CoMod » Tue Dec 27, 2016 7:46 am
На данный момент нет способа открыть закодированное по Block Privacy.
Как вариант можно выложить копии экранов Симатик Менеджера с перечнем функций
типа
выложить на файлообменник слитую программу или образ карты ММС... может там на самом деле KnowHow.
На мудака подать в суд... это если он работал штатно или по бумажному договору - неправомочное... вредительство и т.д.
CwcPLC
Post
by CwcPLC » Wed Mar 01, 2017 7:52 am
Hello everyone
After the function block has been encrpted, how could I unlock it?
Or is there any way to unlock the red block
thank you
hanjinxing
Post
by hanjinxing » Fri Oct 06, 2017 2:48 am
CwcPLC wrote:Hello everyone
thank you
There is no way at present
