[?]: iFix 4.5 and a plc simulator s7 300 cpu
automator
Post by automator »
i want to know if i can how my scada programs will work using a s7 300 simulator or any generla plc simulator that can establish a connection to the iFix software,
is there a plc simulator provided to try iFix programs ?
dibolo
Post by dibolo »
you can work but first you have to run the simulation (s7300) and then open the ifix.be carefull what adress you give.check the mission controll or pmon to see the results (no data or com problems).
automator
Post by automator »
do you mean the plcsim simulator that comes with step-7 ?
ive heard that it cannot establish a communication with a scada software if its not made by SIMATIC, true?
dibolo
Post by dibolo »
no it is not true.you can make at least with ifix and fix32 just take a look
from my computer. :wink:
[dead] :/200137899/simulation.bmp
dibolo
Post by dibolo »
let me know if its working with you
automator
Post by automator »
thanks dibolo
i will let u know what happens when i try it
