most
Posts: 431 Joined: Sat Oct 22, 2005 7:17 am
Post
by most » Tue Feb 17, 2009 11:23 am
I need an information (siemens is very complicated for me
to use an TS Adapter 6ES7 972-0CA30-0XA0 in direct connection with S7-300 I need the program TeleService or this program is only for connect via modem
most
Posts: 4090 Joined: Thu Feb 16, 2006 3:25 pm
Post
by CoMod » Tue Feb 17, 2009 11:50 am
most wrote: I need an information (siemens is very complicated for me
most
You need install drivers from program TeleService.
Key is not required for drivers.
dibolo
Posts: 74 Joined: Fri Mar 03, 2006 10:18 am
Post
by dibolo » Tue Feb 17, 2009 11:52 am
You can also look at this.It's very usefull and it has the connection procedure.
[dead] :/199158153/6ES7972-0CA23-0XA0.pdf
most
Post
by most » Tue Feb 17, 2009 4:33 pm
thanks CoMod and dibolo for help.
perhaps the adapter is damaged. I do not obtain light in power led.
it is possible damages when by mistake i inverted connect MPI with RS232 ?
most
