[?]: xbtz925 cable diagram TSXCUSB485
Obyrvalg
Post by Obyrvalg »
Hi i can't find xbtz925 cable diagram.
This cable between TSXCUSB485(RJ45)
and terminal Magelis XBT N/R(rj45 or d-sub25).
Known anybody pinout?
Thanks.
Здравствуйте! Не могу найти нигде схемы кабеля XBTZ925. Применяется для соединения адаптера TSXCUSB485 и терминалов Magelis (Telemecanique).
Бывает двух видов "А" rj45-rj45
и "B" rj45-dsub25.
Есть ли у кого схема? Спасибо.
Umencho
Re: [?]: xbtz925 cable diagram TSXCUSB485
Post by Umencho »
Isn't be possible to use XBT-Z915 (serial cable)? The transfer speed is the same and price less then USB + adapter + drivers. Here with search you can find pinouts of this serial cable.
regards
Obyrvalg
Post by Obyrvalg »
Hi!
Umencho wrote:Hello,
The price less then USB + adapter + drivers.
I already have TSXCUSB485 and driver, but my notebook without comport. TSXCUSB485 working correctly together Modicon TSX and Twido... My other USB->COM adapter (base on PL2303 chip) + cable TSXPCU1030 + Modicon TSX Micro dont operates, although same baseon PL2303 adapter + cable TSXPCU1030 + Twido = OK. I dont sure, will be working adapter baseon pl2303+XBTZ915+HMI. Price two rj45 and two meters twist pair - few cents.
I try diagramm:
side XBT side TSXCUSB485
1 not connect 1
2 not connect 2
3 not connect 3 port mode control
4---------------4 D1 (B)
5---------------5 D0 (A)
6 not connect 6 RS 485 dtiver enable (input)
7---------------7 power supply 5V
8---------------8 common
but fails... Variants?
cleberpm
Post by cleberpm »
Did you have sucess with cable ??? Can you send a pinout ????
Petrozawodsk
Post by Petrozawodsk »
Side 1(Panel) Side 2(TSXCUSB485)
3--------------------1---
4--------------------4 |
5--------------------5 |
7--------------------7 |
8--------------------8---
3-8 connected, 1-8 connected
TSX CUSB485 pinout
               RJ45
1 | N.C.     |
2 | N.C.     |
3 | PMC      | Port Mode Control
4 | D1 (B)   | Transceiver Terminal 1
5 | D0 (A)   | Transceiver Terminal 0
6 | NDE      | RS485 Driver Enable (INPUT)
7 | VP (OUT) | Power Supply (5V, 500 mA max)
8 | Common   | Signal and power supply Common
found from inet. regards.
But with xbtz915 and prolific usb-com cable is possible connect to magelis panels too.
ciwa
Post by ciwa »
Hi Petrozawodsk,
Could you please send me the xbtz915 scheme?? thanks.
Regards,
Ciwa
Petrozawodsk
OK.
[dead] :/290762310/XBTZ915.pdf
Note. There is an old RS-232 pinout. In modern PC pin 1 is not PG, i.e. pin 1 is not connected to ground chassis.
King regards.
ciwa
Post by ciwa »
thanks..
