Greetings,
can anybody post/upload PPI Protocol description notes/spec here or send it to mail: electronicsmith(at)gmail.com
MPI/Profibus would be great too.
Thank you
[?]: Siemens PPI Protocol description notes/spec.
jhanus
Umencho
Hello
About PPI Look at manual, see appendix A for pinout:
http://support.automation.siemens.com/W ... en/1109582
About MPI/Profibus Look at part 6.3 of
http://support.automation.siemens.com/W ... n/14053309
regards- MPI is PROFIBUS based and is using the regulations of PROFIBUS too... So you have max. 256 Byte long telegrams with Header and Taylor like PROFIBUS.
- PPI is RS485 based and closely to PROFIBUS but due to the smaler performance for Communication the PPI Telegramm can contain gaps within the Data... so you have usually no defined Telegramlength like you would need it for PROFIBUS. Due to this MPI and PPI do not work together.
jhanus
Thank you for information, but I was thinking about detailed specifications about (PPI)OSI layers and how and when which bytes are sent and which information they carry.
Like TCP/IP is defined and widely known, which and with what purpose is every byte sent.
Sorry if I'm a bit unclear, my main concern is PPI protocol.
jhanus
inwestor
