you master write the ouput and read the input, the input and the output gone in the V memory.
tips here
if you configure the slave in consistency area dont forget the SFC15 SFC14.
this means that ill configure the s7 200 as EM then ican used simatic manager to prog ram the S7-200 dirctly using the 315 as master. Is that wat u mean?
