[?]: Profibus DP OPC server for iFix
tuangp
Post by tuangp »
Everybody can show me how to connect iFix (master) to profibus network devices?
Have you got "Profibus DP OPC server"? Please share it for me.
Thanks.
marcs7
Post by marcs7 »
tuangp
Post by tuangp »
I think Simatic net only support for SIEMENS products. I need communicate SCADA server (iFIX) with other conntrollers via Profibus network.
marcs7
Post by marcs7 »
you say : a profibus DP network, profibus is a standard in industrial automation, with the OPC dp master server yes you can :D
just put the gsd file for the configuration.
SCADA opc client <------->OPC server DP(master)<------->slave
for a profibus opc master dp a CP5611 A2 (pci mode)
another link here
tuangp
Post by tuangp »
Thanks marcs7.
If WinCC(CP5613) <------->OPC server DP(master)<------->slave-----> OK, no problem :) .
But iFIX(CP5613)<-----> which OPC Server??? <------> slave ----> Is it possible :roll: ???
Have you ever used iFix with Profibus Interface Card (CP5611/5613)? How to import gsd file to iFix?
Thanks again.
tuangp
Post by tuangp »
Little_Cat wrote:No. Profibus Interface Card (CP5611/5613) card can be configured only in Siemens Configurator and for Siemens OPC Server.Server is a DP maste
IFix in this case is only the OPC client and GSD files that you need can be imported in configuration of server
Agree with Little_Cat. That is the reason why I'm loocking for OPC Server for Profibus
marcs7
Post by marcs7 »
that what i said before
marcs7 wrote: SCADA opc client <------->OPC server DP(master)<------->slave
