[?]: crash wincc flexible 2008
maher
Post by maher »
hi all
i downloaded the wincc flexible 2008 from the current links here 4 monthes ago, and i made more of projects on it .
but yesterday when i opened the program something was happened:
_ the program was opened after that i selected the project which i wanted to open it ... but the project wasn't accepted to open only the blue page was appeared without my project and also without any message also.
_ I tried to unistall the program by add or remove program the message was appeared.
PLEASE CLOSE THE APPLICATION WINCC FLEXIBLE , REBOOT YOUR COMPUTER AND START THIS SETUP AGAIN
_ So i made restarting for my computer and tried to unistall the program by the previous precedures also the same message was appeared again.
what can i do to repair the program or to unistall it for install it again ?????
i am going to wait your repling as soon as possible.
best regards
maher
CTRL+ALT+DEL
Task manager
end HMI process
or
http://support.automation.siemens.com/W ... n/22407360
and remove regkey
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\
WinCC flexible Smart Start
"C:\Program Files\Siemens\SIMATIC WinCC flexible\WinCC flexible 2008\HmiSmartStart.exe" /startup
