[?]: license of Simatic IT Production Suite v6.1 SP
jackjoy
Post by jackjoy »
I download simatic it v6.1 from http://plc.net.ru/viewtopic.php?t=5467 and installed ok.But i could not run "simatic it services",error message is about license.How and where could i get and install the license key correctly.Please help!Thanks a lot !
jackjoy.cn@gmail.com
before post use search :evil:
http://plc.net.ru/viewtopic.php?t=218
don`t duble post!
jackjoy
Post by jackjoy »
I tried all as http://plc.net.ru/viewtopic.php?t=218 said,but still could not make "simatic it services" (plant management) to function correctly,nearlly all the menus are garyed.(license Violation)I can't create new plant.
The keys in c:\af** are checked ok,but in auto license manager(ALM v2.2),the "licensed software" and "installed software" view, only one item----- Logon service.In EKB install, the "required keys" view also has only one item --- Logon Service. I guess i have to create a yellow disk,but when i created a disk with the tools inside "simatic it" v6.1 package,ALM tell me the key in floppy disk are all coruppted(c18),what shoud i do?
Has anyone just installed and run Simatic it production suite ok?I really need your help.
See Simatic IT folders in EKB_Install with 63 keys !
and EKB_Install Help file EKBInst.chm
no need create YD - need install keys direct to HD from EKB_Install.
jackjoy
Post by jackjoy »
Thanks for CoMod's reply.
I've installed Simatic IT keys using EKB_Install,and all keys are checked ok in ALM v2.2 and can transfer between hard disks.
But when staring "simatic it services",it always prompts "License violation" and all the menu of "plant management" are grayed
(could do nothing, even for exit).
I'm really being crazy!
jackjoy
Post by jackjoy »
I found that exist a error log when starting ALM,it is:
"Plugin Almpgiipcx.ALMPlugIn CoCreateInstance failed with 0x80040154."
I am not sure if this is the problem that made "Simatic IT" license failed.
The reason is lack of a file: IPCSE_LM.DLL
Can anyone can send me "IPCSE_LM.DLL"?
Thanks a lot!
jackjoy wrote:I found that exist a error log when starting ALM,it is:
Can anyone can send me "IPCSE_LM.DLL"? Thanks a lot!
Try to install ALM v3 or v4
jackjoy
Post by jackjoy »
Thaks for CoMod agian.
I guess is the version not match with the products.All EKB_install package provide license of simatic it v6.1 ,but from http://plc.net.ru/viewtopic.php?t=5467,we got simatic it v6.1 SP1,the version is not exactly matched.
Below is simatic it v6.1's component:
* SIMATIC IT Services 5.0
* SIMATIC License Manager
* SIAMTIC Logon
* SIMATIC IT Client Application Builder (CAB) 1.1
* SIMATIC IT Business Process Modeler (BPM) 5.0
* SIMATIC IT Production Modeler (PM) 5.0
* SIMATIC IT Data Integration Service (DIS) 1.1
* SIMATIC IT Product Definition Manager (PdefM) 1.0
* SIMATIC IT Production Order Manager (POM) 5.0
* SIMATIC IT Material Manager (MM) 5.0
* SIMATIC IT Personnel Resource Manager (PRM) 2.0
* SIMATIC IT Barcode Scanner Manager (BSM) 2.0
* SIMATIC IT Production Operation Recorder (POPR) 5.0
* SIMATIC IT COM Interface for SIMATIC BATCH (CIB) 2.0
Below is simatic it v6.1 sp1's component:
(http://plc.net.ru/viewtopic.php?t=5467)
* SIMATIC IT Services 5.0 SP1
* SIMATIC Automation License Manager 2.2
* SIMATIC Logon 1.3
* SIMATIC IT Client Application Builder (CAB) 1.1 SP1
* SIMATIC IT Business Process Modeler (BPM) 5.0 SP1
* SIMATIC IT Production Modeler (PM) 5.0 SP1
* SIMATIC IT Data Integration Service (DIS) 1.1 SP1
* SIMATIC IT Product Definition Manager (PdefM) 1.0 SP1
* SIMATIC IT Production Order Manager (POM) 5.0 SP1
* SIMATIC IT Material Manager (MM) 5.0 SP1
* SIMATIC IT Personnel Resource Manager (PRM) 2.0 SP1
* SIMATIC IT Barcode Scanner Manager (BSM) 2.0 SP1
* SIMATIC IT Production Operation Recorder (POPR) 5.0 SP1
I guess simatic it v6.1 sp1 has a different license key.
I'm nearlly mad!
Can anyone help me?
anyway,Thanks to CoMod and plc.net.ru again.
jackjoy wrote: I guess is the version not match with the products.All EKB_install package provide license of simatic it v6.1 ,but from http://plc.net.ru/viewtopic.php?t=5467,we got simatic it v6.1 SP1,the version is not exactly matched.
All key tested with Simatic it v6.1 SP1 and work Ok
1. Install Production Suite
2. Add user in ALM User Managment
3. Run Simatic IT services
jackjoy
Post by jackjoy »
OS: Windows 2003 + SP2,dual core
(1) all keys checked ok ( ALM 2.2,ALM 3,0+sp1,ALM 4.0 all tried)
(2)start "simatic it services",prompt error
(3) all menus are grayed(disabled) in "Plant management",can do nothing,even for exit the program
jackjoy wrote:(1) all keys checked ok ( ALM 2.2,ALM 3,0+sp1,ALM 4.0 all tried)
But Not all keys installed
jackjoy
Post by jackjoy »
Thanks again!
Problem still exist! Since i only installed "Production suite"(not install reporting manager,unilab,historian),the 33 keys should be enough!
I tried the 60 keys for all types( floating,single,rental),the only different thing is the "license violation" prompt disappeared,but menus of "plant management" still grayed(disabled).
jackjoy
Post by jackjoy »
After a week's effort,i decide to give up.I tried in serval computers,but none can work fine.I cannot figure out what's wrong.Since the ALM can not show the properly "installed software"(only logon service),i guess something is wrong in setup/install process.But no error displayed during setup.
Anyway,Thanks again to CoMod and plc.net.ru.I'll come back sometime.
mike1978
Re: [?]: license of Simatic IT Production Suite v6.1 SP
Post by mike1978 »
Hello, does somebody knows whre to download the Simatic it v6.1?
Please, its really important.
