[?]: Fix WinCC Flexible 2008 install problems
beerka
Post by beerka »
1) If your Windows XP is not english
you may have problems when WinCC Flexible installer check your OS.
In this case try to Run:
\install_image\CD1\setup.exe /nooscheck
2) If you have problems when WinCC Flexible installer install SQL server:
after install stopped, delete all temporary files on c:
(run Cleanmgr.exe), and start the install again
Dreamer76
Re: [?]: Fix WinCC Flexible 2008 install problems
Post by Dreamer76 »
beerka wrote:1) If your Windows XP is not english
hmm thanks but i install winccflex 2008 on winxp sp2 in german and czech and had never probs... :?:
