any one there to help me out,
i have uploded s7 programe to programmer
but canot find any symbol & comment
so i copied the symbol table to the backup
i got the symbols
but still i am not able to get the comments in backup
i have the original copy of programe with me
[?+]: restoring comments & symbol in s7 backup prog
hand_drake is correct..
the symbols and comments are left in programming device when u download it in the plc..(cause of type memory use).
luckily u have back up program, but still only the symbols will do..and the comments...copy it one by one from yur back to the uploaded..
i hope it will help..happy new year!!!!!!!!
If you want to have comments, but the same as symbol file (the same as output coil in every network, will be assigned to the network comment.)
I always do it if my project is too long. This methode makes my time saving.
In a Function (FC) or Function Block (FB) or Organization Block (OB) Editor of Step7, change to STL (by pressing CTRL-2). Just press down the cursor from the top to the bottom. Then automatically network comment changed as the same symbol output coil. Then you can change again to the LAD (by pressing CTRL-1) or what ever view mode LAD/STL/FBD as you want.
Note: this methode will carried out if you have the symbol file, such as copying the old symbol project to the new project file. Or making the symbol by your self.
Good luck.
Good luck.
