[?]: convert Gray code to binary code using ladder diagram
CX-One, CX programmer, NTST, Syswin ....
ahmed yousri
Post by ahmed yousri »
can i convert Gray code to binary code using ladder diagram ,
if there is document pls uploaded it
http://en.wikipedia.org/wiki/Gray_code
Here is an algorithm to convert Gray code to natural binary codes (decode):
C function
unsigned int graydecode(unsigned int gray) {
   unsigned int bin;
   for (bin = 0; gray; gray >>= 1) {
     bin ^= gray;
   return bin;
Let G[n:0] be the input array of bits in Gray code
 Let B[n:0] be the output array of bits in the usual binary representation
   B[n] = G[n]
   for i = n-1 downto 0
     B[i] = B[i+1] XOR G[i]
3-bit Grey code
Dec  Gray   Binary
 0   000    000
 1   001    001
 2   011    010
 3   010    011
 4   110    100
 5   111    101
 6   101    110
 7   100    111
Schtiel
Re: [?]: convert Gray code to binary code using ladder diag
Post by Schtiel »
ahmed yousri wrote:can i convert Gray code to binary code using ladder diagram
of course yes, for what PLC do you need the program?
Олег
Contact:
Post by Олег »
GRAY CODE CONVERSION (GRY(474)) for Easy Conversion of Parallel Inputs from Absolute Encoders
to Binary, BCD, or Angle Data
This instruction converts Gray binary codes to binary, BCD, or angle data.
This enables easily handling position or angle data input as parallel signals
(2n) from an Absolute Encoder with a Gray code output using a DC Input Unit.
ahmed yousri
plc type "omron"
Info
Faq & Info
Faq & Info
Post by Info »
gray code to decimaly this XOR command
see S7 STL code
L0.2 - L0.7 this no use bits (encoder 10 bits)
      L     #IN0              // IW encoder
      T     #encod_gray_dec   // LW0
      SET
      R     L      0.7
      R     L      0.6
      R     L      0.5
      R     L      0.4
      R     L      0.3
      R     L      0.2
      AN    L      0.1
      JC    M003
      AN    L      0.0
      =     L      0.0
M003: AN    L      0.0
      JC    M004
      AN    L      1.7
      =     L      1.7
M004: AN    L      1.7
      JC    M005
      AN    L      1.6
      =     L      1.6
M005: AN    L      1.6
      JC    M006
      AN    L      1.5
      =     L      1.5
M006: AN    L      1.5
      JC    M007
      AN    L      1.4
      =     L      1.4
M007: AN    L      1.4
      JC    M008
      AN    L      1.3
      =     L      1.3
M008: AN    L      1.3
      JC    M009
      AN    L      1.2
      =     L      1.2
M009: AN    L      1.2
      JC    M010
      AN    L      1.1
      =     L      1.1
M010: AN    L      1.1
      JC    M011
      AN    L      1.0
      =     L      1.0
M011: NOP   0
      L     #encod_gray_dec
      T     #OUT1             //decimaly out encoder
Scarch
Post by Scarch »
Thanks sania, I will try it soon.
