[?+]: Proficy Me 4 day trial reset
другие контроллеры
Beavis
Post by Beavis »
Hi!
To reset the 4 day trial in proficy ME create the following batch file:
@Echo off
Echo GEFuck, version 0.0 courtesy of Beavis
REG ADD HKLM\Software\Taylor\Workbench\Configuration /v CurrentMessage /t REG_MULTI_SZ /d {91BEDA33-ABD5-4B98-9F34-2549C7871160} /f >nul
REG ADD HKLM\Software\Taylor\Workbench\Configuration  /v LastMessage /t REG_MULTI_SZ /d {651EAA2E-B8DC-4418-976E-5F525D63BA42} /f >nul
REG DELETE HKLM\Software\Taylor\Workbench\Configuration  /v Size /f >nul
cd "%programfiles%\GE Fanuc\Proficy Machine Edition\Common\IDE\"
start "" "%programfiles%\GE Fanuc\Proficy Machine Edition\Common\IDE\FrameworX.exe"
Echo Thanks.
Tested in ME 5.7; should work on above versions as well.
You can use this batch to start ME instead of provided icon.
Bye! :D
throwaway
Re: [?+]: Proficy Me 4 day trial reset
Post by throwaway »
This worked for me. Proficy ME v9.50 build 7677. Updated batch file code was:
REG ADD HKLM\SOFTWARE\Wow6432Node\Taylor\Workbench\Configuration /v CurrentMessage /t REG_MULTI_SZ /d {91BEDA33-ABD5-4B98-9F34-2549C7871160} /f >nul
REG ADD HKLM\SOFTWARE\Wow6432Node\Taylor\Workbench\Configuration  /v LastMessage /t REG_MULTI_SZ /d {651EAA2E-B8DC-4418-976E-5F525D63BA42} /f >nul
REG DELETE HKLM\SOFTWARE\Wow6432Node\Taylor\Workbench\Configuration  /v Size /f >nul
cd "C:\Program Files (x86)\Proficy\Proficy Machine Edition\Common\IDE"
start "" "C:\Program Files (x86)\Proficy\Proficy Machine Edition\Common\IDE\FrameworX.exe"
Thanks OP!
diegofanti
Post by diegofanti »
Thank's Bro! Works for me... (oo)
