Hello dear all , I need to drive few inverter Danfoss vlt2800 with a cpu 315-2DP via profibus .
Anyone have an example FC or FB ?
any help is appreciated !
[LINK]: example drive inverter Danfoss 2800 with 315-2DP
zzz-zzz
dsekulic
You just need GSD file from vlt2800 and import them in hardware configuration.
Than parametrize vlt2800 instance in HWconfig and download to S7-300.
All input data You should see in PII (from HWconfig) and commands are writed in PIQ (from HWconfig).
That's all.
Also if vlt2800 support DPV1 than You can communicate asynchronicaly with inverter.
http://www.pribor-servis.ru/downloads/d ... 90E102.pdf
GSD and example
http://www.danfoss.com/businessareas/dr ... +files.htm
regards
That's all.
GSD and example
regards
dibolo
very helpfull.thumbs updsekulic wrote: http://www.pribor-servis.ru/downloads/d ... 90E102.pdf
GSD and example
if you want,you can try it
http://plc.net.ru/viewtopic.php?t=68
