I have downloaded and install EPLaN 1.9 & Dataportal and its clear that you need a valid user name & password to log on the server to update part lists, I found as well some databases for eplan in the format of txt or mdb but non I suceeded to import to eplan so I wish if some one have the knowledge to explain how to import such data to eplan or if someone have a complete database to export it from eplan V1.8 at least not V5 and uploaded here so every one can make use of this program
those are some links for database i found here
http://plc.net.ru/viewtopic.php?t=6862&highlight=eplan
http://plc.net.ru/viewtopic.php?t=8338&highlight=eplan
http://plc.net.ru/viewtopic.php?t=7814&highlight=eplan
http://plc.net.ru/viewtopic.php?t=7761&highlight=eplan
thanks
[?]: How import EPLAN DATABASE
engineer66
gregar
engineer66
I have read this thread before and try it but it didn't work that why I'm asking someone having complete database in EPLAN P8 and export it from it so that we can import it directly to the program as most of the links above are from EPLAN 5 which imported partaley sometimes data without macros or macros without active connection points things liks that.
