[SCL?] DIFFRENT DATATYPE ASSIGNMENT
frankw
Post by frankw »
The compiled SCL :
      L     D [AR1,P#128.0]; <-------point to DB1.Err.Err0, structure with 32 bool
      T     #Err_DW;<-----------------Dword data type
how to rewrite it in SCL ?
       Err_DW := which_convert_function(DB1.Err.Err0)
Best Regards
frankw
Post by frankw »
The code is part of EasyMotion 2.0 FB1 MC_MoveAbsolute:
compiled code:
A7d6:   L     #Restweg
      T     #ziel
      L     #aufl
      /R
      T     #ZielStrich
      L     DIW [AR2,P#22.0]
      T     LW    90
      TAK
      OPN   DB [LW 90]
      L     DID [AR2,P#24.0]
      LAR1
      TAK
      L     D [AR1,P#128.0]
      T     #Err_DW
      CLR
      =     L     84.0
      =     L     84.1
rewrite it in SCL:
VAR_TEMP
  Err_DW : DWORD ;    //internal use
  Err_DW_Bit AT Err_DW: ARRAY [0..31]OF BOOL;   //BIT VIEW OF DWORD
END_VAR;
            ziel := Restweg;
            ZielStrich := Restweg/aufl;
            Err_DW := Axis.Err;//*******NEED CORRECTION!*************
            Err_DW_Bit[0] := FALSE;
            Err_DW_Bit[1] := FALSE ;
help me, please.
frankw
Post by frankw »
now it work:
               TEMP_VAR
               Err_DW : DWORD ;
               Err_Struct AT Err_DW :STRUCT // ADDED same as DB1.Err;
               END_STRUECT;
               END_VAR;
                Err_Struct := DB1.Err;
After compiled:
       L     D [AR1,P#128.0]
       T     #Err_DW
