Hi
I´m trying to insert data from IAS of wonderware to a SQL2000 table, i did use a script and these work fine but only with numeric data, if i try with the data of the PLC´s doesnt work.
This is the error:
Filed to convert parameter value from a external reference
[?]: Problem with IAS of Wonderware and SQL2000
Yvan
