Dear all,
i just bought a second hand cp5511, but i don't have the sofware cd.
i use the CP to communicate with S7 plc with no problem.
I have simatic S7 manager V5.4 and simatic net 2006 installed on my laptop.
My problem is when i need to connect my CP with IM308C (S5 PLC) with comprofi bus, it says that station cannot be reach.
i test my card from setting pg/pc, it was OK (see 2.jpg). but if i connect to im308c and test it from setting pg/pc nothing happen although i have waited for half an hour.
My question is:
1. do i need a software driver for cp5511? if yes could someone share it?
2. please help.
thank you in advance
[?]: cp5511 communication with im308c
cemara
cemara
i have install comprofibus v5.1 with hf1, hf2, and hf3. but i still could not connect to im308c. while using cp5511 connected to im308c and using set pg/pc to test the bus, i could not get any result. but hen i disconnect cp5511 from im308c and do diagnose from set pg/pc everthing is ok. does this cp5511 need a software driver? anybody could share it please? thank you in advance.
