[?]: ifix 5.0 KEY
xiaxueyiyi
[?]: ifix 5.0 KEY
who has a ifix 5.0 key, share with me, okey?
wangrenzhi
Do you need other data? What exactly? To change data is not big problem...wangrenzhi wrote:????????????????????
Only 2015-12-31
I was try to make for 4.5 russian, but not succeed.
Can try to do for 4.5 english, but can't test it (don't wish to uninstall/install different versions). If anybody need - write here!
Use it only for education and short development period!!!
Things that make a money must be payed!
There are 3 bytes in license.sys by offsets 0x76...0x78 that define expired date. But with changing them also changed a few else settings (like max I/O points, Historian points and connections and some others). So, there must be changed several bytes accordingly to eleminate unneded affection. I found that for 5.0 - max date with correct displayng day of week and name of month is within of 2034 year. After it date will be shown in iKeyDiag as, for example, "M:12, D:31, Y:2035"lwdzxy wrote:How to change date
Good luck!
P.S. Is anybody have work license for any russian version iFIX?
PROFICYLIC.zip
http://narod.ru/disk/10480622000/PROFICYLIC.zip.html
or
[dead] :/250652176/PROFICYLIC.zip
or
wangrenzhi
underplc wrote:PROFICYLIC.zip
or
Runtime 2 hour
rohit02988
Re: [?]: ifix 5.0 KEY
Plz share ifix 5.0 key
