[?]: How to key parameter using Starter, Sinamic G120.
Questions about Siemens & Analog Siemens hardware.
Software & hardware exchanger
Sie-auto
Contact:
Post by Sie-auto »
Dear all experts,
I try to learn Starter software (before I used DriveMon to confingurated drive).
How can I change value for e.g I want to use OR element out put r2817 to close (change state) digital out put relay (Pin18,19,20) so I interconnected r2817 to this out put.
Troube is I don't know how to change P2816 index 0,1 value and also P2800 and 2801[3].
Please review attach pictures for more detail.
Sorry I can't attach the pictures so if you have G120_ParMan_27864391_1007_en.pdf document sheet 4800 you can see that Free Block.
Can you show me solution or advice for this problem?
Thank so much
GDMaso
Post by GDMaso »
when you are online you with the right click mouse on the object tree go in expert list
in this page you are able to change all data you want according the parameter number and index
bye
