Dear Experts
I need to know the steps that I can use PLCSIM4 in order to communicate with WinCC Flexible thus I can simulate my system
[?]: WinCC Communication with PLCSIM4
NouTec
FAQ
WinCC
http://support.automation.siemens.com/W ... n/21914005
http://support.automation.siemens.com/W ... en/1026428
Protool = Flexible
http://support.automation.siemens.com/W ... n/13283804
If there is no MPI card installed in the configuration computer, then at least the PC adapter must be installed as interface for STEP 7 V5.*.
Please proceed as follows:
1. Select Start >SIMATIC > STEP 7 > Set PG/PC interface.
2. Click the "Select" button in "Interfaces Add/Remove".
3. Select "PC-Adapter" in the left window.
4. Click the "Install" button.
5. Close the dialog.
6. For "Access Point of the Application" set "S7ONLINE > PC Adapter".
Communication between WinCC/WinCC Flexible/ProTool/ Runtime and PLCSIM V5.* is enabled in this way.
WinCC
Protool = Flexible
NouTec
PLCSIM Version
I am sorry for the delay CoMod
The version is PLCSIM v5.3
I also want o know when I use the Simatic manager I must choose PC Station or HMI station? at the same time I must inside WinCC Flexible to choose WinCC Runtime
I am waiting for your reply
Thanks in advance
Thanks in advance
reymond_craig
