[?]: error s7_get_initiate_cnf
Yvan
Post by Yvan »
This error happens when we try to get data from a CP1623 card through wonderware, its happens only when we try to get DB types TAGs.
We use the Items type in this way: DB315,DINT58 when we use data type like MB or Int dont ocurre the error.
Thanks for your help.
i think you need write DB315,D58
Umencho
Re: Help error s7_get_initiate_cnf
Post by Umencho »
Yvan wrote:This error happens when we try to get data from a CP1623 card through wonderware, its happens only when we try to get DB types TAGs.
hello
The 's7_get_initiate_cnf()' call, receives the result of the S7 connection
establishment. With the 's7_receive()' call, the user program receives the
'S7_INITIATE_CNF’ confirmation if the establishment request was
processed.
Now, can you give us more information about this tag. You inserted like I/O Real or I/O Int type. And in your DB is this inserted like DINT. Which I/O server you use to establish connection from PC and PLC?
regards
Yvan
Post by Yvan »
Thanks for your answer!!!
Yes we did try DB with REAL and DINT just like this:
DB364,DINT130
DB364,REAL130
DB364,X130.0
This items did not work, the only items that are working are MB and IB.
The I/O Server that we are using is a DAServer of Wonderware call DASS7 that communicates with the CP1623 (Upgrade of CP1613) and the card with the S7 PLCs.
Thanks!
