[?]: Cable for Simatic S5 IP266 communication
Questions about Siemens & Analog Siemens hardware.
Software & hardware exchanger
redcruiser
Post by redcruiser »
Hello everyone,
i am a new fish, i have a problem,can you help me?
In my foaming machine control system, there is an old module Simatic S5 IP266,
i need a programming cable to communicate between IP266 (PG port DB15 ) and PC(RS232 DB9),
but i cannt buy the programming cable and i cannt find out the pinout schema of the cable.
redcruiser
Thanks to you.
the first pdf file cannt open correctly.
and i use the RS232/TTY cable to communication between IP266 PG port and PC COM,an error occured"F53 watchdog error PCB".why?
Redcruiser
redcruiser wrote:the first pdf file cannt open correctly.
PDF opened without problems
redcruiser
OK! Thanks very much.
Regards
Redcruiser
marcs7
Post by marcs7 »
there are problem with actual CPU and some IP or COM software, found a old cpu for solve the problem.
i take care of my old dell laptop with serial com and PII processor :wink:
