[?+]: the communication between plc and drive lenze
maher
Post by maher »
Hi all
it is first time for me to create the network consist of plc S7(315-2DP) and drive lenze (9300 vector).
but in the fact i haven't any information about the data transfering between the plc and drive to control on it.
please i want to learn the steps to make it and applications to demonstrate it for me.
mean by steps that
- how can i transfer the data between them to make the control on for example( enable for the drive ,speed ,direction ,...etc)
- the blocks which we need .
- i need to make full control on the parameters for the drive .
best regards
maher
Umencho
Post by Umencho »
Hi
Isn't this enough? https://www.automation.siemens.com/WW/f ... age=en#top :lol:
To be integrated in different Profibus-DP configuration softwares (in your case Step 7 ) you need GSD file depends fro module designation (installed profibus card in your drive). You can download fro here:
GSE files for Lenze Profibus-DP communication modules http://akb.lenze.de/akb-englisch/infopo ... /200412329
And after that follow this: Program example Profibus-DP with Siemens PLC S7
http://akb.lenze.de/AKB-englisch/infopo ... /200413406
regards
maher
Post by maher »
:lol:
thanks alot
maher
detective
Re: [?+]: the communication between plc and drive lenze
Post by detective »
https://drive.google.com/file/d/1dQKtEP ... sp=sharing
Above is link of screenshot for step7 lenze profibus network
on right side the are Pzd(4w kons) , Pzd(5w kons), Pzd(6w kons) these must be address of lenze drive parameters but does anyone have exact cross-reference of theses with lenze 9300 paramter for example if i want C0081 Rated motor power which "Pzd " will be used. ???
