Dear experts,
Good afternoon, i have an Intouch project with S7-400 PLC.
Now my question is, can we communicate Siemens PLC Sim 5.4 to Intouch.
It seems PLC SIM is not communicating to my wonderware even you configure PLC Sim to run in ethernet.
This will help me reduce my comissioning time if there's a way of communication between wonderware and PLC sim.
Thank you very much in advance..
Beginner
[?]: Siemens PLC Sim communicate with Wonderware
reymond_craig
Schtiel
I am not sure, but you can try to use S7 IOServer from Wonderware and then follow these steps:
http://61.37.246.137/TECH/html/t000948.htm
May be it will work...
Umencho
Hello
No It's not possible. S7-PLCSIM does not support any communication functions.
You can read here http://www.automation.siemens.com/WW/fo ... stID=96908 some way but ...
Try with using WinLC. And post result
regards
regards
fanren
S7-PLCSIM can connect with WinCC. Why not be connect with intouch?Umencho wrote:Hello
No It's not possible. S7-PLCSIM does not support any communication functions.You can read here http://www.automation.siemens.com/WW/fo ... stID=96908 some way but ...
Try with using WinLC. And post result![]()
regards
It's not a question of communication.
Umencho
Hi
The connection from S7-PLCSIM to STEP7, Protool and Win CC is by some internal "shortcut" that replaces the ordinary MPI connection with the simulated MPI connection to S7-PLCSIM.
PLCSim detours S7ONLINE access point for PG Layer 4 to PLCSim interface so any application (STEP7, WinCC, ProToolPro) that uses S7BlockServer (PG Layer 4) hits PLCSim when use S7ONLINE access point. S7 OPC ( Intouch I/O Server, IFIX, ....) does not use S7BlockServer (uses S7-API) for communication.
TO SIMULATE I/O NEED real PLC.
REGARDS
REGARDS
negotio
Alternative solution
Unfortunatly it is not possible for other programs to connect to PLCSim. But I recently found a program called WinPLC-Engine on the MHJ website (http://www.mhj-software.com/). I think this program will do the job.
negotio
AMB
I found this TCP/IP-Network extension for the PLC simulation software Siemens PLCSim (required Step 7 V5.4) :
http://sourceforge.net/projects/nettoplcsim
Try it
Try it
Setup of your client software
The computer on which PLCSim and NetToPLCSim is running represents your PLC.
So in your client Software (SCADA/HMI/OPC) you have set the IP address of the PLC to the IP address of the network interface of the PLCSim computer, or set the IP of your network interface to the IP your PLC will later have.
NetToPLCSim don't cares about the rack/slot specifications, and handles a max. PDU size of 960 bytes.
Tested with some SDCADA/HMI systems:
* Wonderware InTouch with DAServer
* Works well. Libnodave itself
* Works well. WinCCflexible 2007/2008
* Siemens WinCCflexible sometimes uses special protocol commands which NetToPLCSim doesn't support. But simple projects will mostly work. If you have large amounts of data and many cyclic data for alarming, WinCCflexible requests the PLC to send cyclic messages with this data without any request from flexible. Simatic Net OPC Server
Works well. But you can't browse the PLC with the OPC-Scout, because it asks the PLC which data blocks are present in the PLC. Nevertheless you can read/write this data.
It will work with any other driver that uses S7-Communication (no configuration or programming in the PLC is needed), and uses no special functions.
How it works
NetToPLCSim uses the S7ProSim COM-Interface of PLCSim, to read/write the data out of it.
A background thread waits for connections on port 102 and handles the S7 communication (ISO on TCP).
fanren
negotio
This is a know problem. Try to set the "Simatic IEPG Help Service" to manual start mode and stop the service. Then the port 102 should be free.After running,prompt :
Fehler! NoDaveServer konnte nicht gestartet werden! Return Value: 3
Grund: Socket konnte nicht an Port 102 gebunden werden (Port evtl. schon benutzt)
But the Port 102 is used by another simatic program. .Can anyone changed the port ?
Dr.Acrobat
WW DASSIDirect and PLCSIM
I try Net to PLCSIM but with problem.
After solve port 102 trouble disabled service DASSIDirect not connected on PLCSIM.
Somebody have idea why ???
Thanks advance.
Thanks advance.
for connection with intouch you can use winac
links : http://plc.net.ru/viewtopic.php?t=6079
within you can run your plc on your pc
