[?]: PROBLEM with Protool v5.1 convert to Protool v6.0
fahrituran
Post by fahrituran »
I Have problem with convert protool v5.1 to protool v6.0,
Same graphips not loaded after, give a fault as
"unexpected file format"
After that v6.0 open but, I can't save.
Fault give again as
"Failed to save configuration"
I must convert to program to v6.0.
Anybody knows, How can i solve problem?
Umencho
Post by Umencho »
Hi
Go to Protool Pro 8) v6.0 SP3 and try again. :roll:
regards
fahrituran
i have Protool v6.0 SP3 and i tried it a lot times.:(
Dreamer76
Post by Dreamer76 »
can you upload it?
ciao
dreamer76
fahrituran
no, ı can't with protool v6.0.
Dreamer76
Post by Dreamer76 »
fahrituran wrote:no, ı can't with protool v6.0.
can you upload the program to rapidshare or so?
so we can try to help you
ciao
dreamer76
