[?]: how to define "double indication" with Intouc
lhnhan
Post by lhnhan »
Dear all
I have problem when i programed intouch HMI. Problem is double indication.
I have 02 I/O discrect tag and I want to define double indication with :
- 00: error .
- 01: open .
- 10: close .
- 11: error .
And how can define it with acknowlege , alarm and history.
Can someone help me to solve it?
Best regard.
PLC_ITA
Post by PLC_ITA »
I havent' idea. It's a beautiful question.
I you discover how to do, please share
thank you
most
Post by most »
I always try to run away from scripts, for me is hard
you have two (A and B) imputs with 4 variable, if you create 3 tags [error(c), close(D), open(E))
tag C a==0 and b==0 or a==1 and b==1 .... is error
tag D a==1 and b==0 .... is close
tag E a==0 and b==1 .... is open
with this 3 tags that you create it is simple to send for event log with out any script
i test this in Cx-supervisor and it works
bunglehead
Re: [?]: how to define "double indication" with In
Post by bunglehead »
lhnhan wrote:Dear all
- 00: error .
- 01: open .
- 10: close .
- 11: error .
Best regard.
It's very simple. Just define another tag with Log Events (and alarm defined). Then trigger it for your '11' and '00' on a condition script.
A better way for me is to rework your PLC program (or something from where do you read) to use one Integer status tag with Hi and Lo alarms in it (with ot without logging as you wish). This's much more scalable (no need to add scripts for every valve or what are you controlling..)
