http://www.infoplc.net/Ejemplos/Ejem_Om ... ammer.html
anyone have this in english
or maybee another diy cxprogrammer->cx supervisor
just some material how to get the scada work with the plc
i use cx one 1.2 and cx supervisor 1.2
schould i upgrade them to a newer version that are more easy to use
[?]: cx programmer cx supervisor getting started
much confusion
the example of the page is for simulation with cx simulator and cx(NS)designer with out hardware.
read this manual
http://narod.ru/disk/3534537000/CX_Supe ... s.zip.html
Wednesday (monday and tuesday I cannot) I go to try to create an example for you with simple imput/output with PLC
however you try to go training with virtual points that CX the supervisor allows ....
most
read this manual
most
that would be great
maybee some good hint about the cofiguration betveen the cx supervisor and cx programmer "with the plc omron cqm1"
im working on a program that alow me to control a pellet burner and a solar system these are acumulated in a storage tank with some sencors and DTO for cutting of power to the pellet burner
hope you could help me
i would be glad if i coul make some registration i a data base
with
heat pellets burner
solar heat
kg burned in the burner
energy storage in the tank
etc etc
if you could make some screen dumbs it would be very nice
The site you have given me say to me i should install a program
but my virus control say it will damage my system
could you upload it to rapidshare ore some other site with no program installation
with
heat pellets burner
solar heat
etc etc
1ª- you have to read a manual, this small example is solely a beginning, it is complicated to make more in a forum, full days for me, little time for this ...
smal project
add points, I use 2 options
import with the CX-server or to add individually in CX-Supervisor
with CX.Server
in menu "export import tool" of CX server creates new file
in edit
setup plc ....add your plc and cpu
setup points ...add points as to desire
with Cx-supervisor
with import points, import all points of cx-server that you created
or add individually points in Cx-supervisor as to desire
to add a memory (CNC and TIM they are in memory TC)
to add bit
Developer
work run time
that is a small example, with good knowledge you can make everything what to want, at this moment I do not have analogical PLC in reserve with in/out to execute a PID
programe and images [dead] :/160951511/most.rar.html
most
smal project
with CX.Server
in edit
with Cx-supervisor
to add bit
Developer
work run time
most
