[?]: dongle eplan vista 64 bit
Тools, Elcad, Eplan, ...
jules
Post by jules »
can anyone read this this manual and translate it
[dead] :/154298097/vusb_xp64.rar
or
http://narod.ru/disk/3208554000/vusb_xp64.rar.html
many thanks
Installation 1C (the Russian accounting program) on х64 WINDOWS 2003 SP1 for usage through terminal access (a basis all the same manual on vusb to 13-th release from Poiuyt)
Installation to carry out under the local manager!
1) the manager of licenses and driver HASP Is deleted old. Reboot
2) Installation 1С without driver HASP
3) Installation of driver HASP of the version with support х64, for example 5.18
(To take it is possible ftp://ftp.ealaddin.com/pub/hasp/hl/wind ... st_x64.zip)
4) To register a key of the register
HKEY_LOCAL_MACHINE \SOFTWARE \Microsoft \Windows \CurrentVersion \Setup
Parameter DWORD with name DisableDecoratedModelsRequirement and value 1. Reboot
5) we Bring a dump (the branch of the register with dumps has varied!! [HKEY_LOCAL_MACHINE\System\CurrentControlSet\NEWHASP\Services\Emulator\HASP\Dump \])
6) Install the driver
Control Panel-> Add Hardware
Yes, I have already connected the hardware->
Add a new hardware device->
Install the hardware that I manually select from a list->
Show all Devices->
Have disk->
Browse-> a way up to the catalogue, with files vusbbus.inf, vusbbus.cat, vusbbus.sys
We answer Yes when the Windows ask about continuation of installation of unsigned drivers.
7) Device Manager-> System devices should appear in Virtual Usb Bus Enumerator. Reboot
8 ) Installation HASP HL driver. To take it is possible ftp://ftp.ealaddin.com/pub/hasp/hl/wind ... mdline.zip
We unpack and is started lmsetup.exe with parameter-i
We check in Device Manager-> USB controllers presence of devices Aladdin HASP Key and Aladdin USB Key.
If there is no such, a reboot and anew item 7)
9) Installation HASP LM driver. To take it is possible
ftp://ftp.ealaddin.com/pub/hasp/hl/wind ... _setup.zip
It is checked up on 14,16 releases + sql2000 - start from the console, through the terminal, start of equipment 1с:сервер with installation of bases and work in them works
It is checked up that sys really 64bit - with sys last versions, come from the author (win98, winnt 32bit), 100 %, those business not in a key of the register do not work
Установка 1C на х64 WINDOWS 2003 SP1 для использования через терминальный доступ (основа все тот же мануал по vusb к 13-ому релизу от Poiuyt)
Установку выполнять под локальным администратором!
1) Удаляем старые менеджер лицензий и драйвер HASP. Перезагрузка
2) Установка 1С без драйвера HASP
3) Установка драйвера HASP версии с поддержкой х64, например 5.18
(Взять можно ftp://ftp.ealaddin.com/pub/hasp/hl/wind ... st_x64.zip)
4) Прописать ключ реестра
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup
Параметр DWORD с именем DisableDecoratedModelsRequirement и значением 1. Перезагрузка
5) Вносим дамп (ветка реестра с дампами изменилась!! [HKEY_LOCAL_MACHINE\System\CurrentControlSet\NEWHASP\Services\Emulator\HASP\Dump\] )
6) Устанавливаем драйвера
Control Panel -> Add Hardware
Yes, I have already connected the hardware ->
Add a new hardware device ->
Install the hardware that I manually select from a list ->
Show all Devices ->
Have disk ->
Browse -> путь до каталога, с файлами vusbbus.inf, vusbbus.cat, vusbbus.sys
Отвечаем Yes когда винда спрашивает о продолжении установки неподписанных драйверов.
7) Device Manager -> System devices должно появиться в Virtual Usb Bus Enumerator. Перезагрузка
8) Установка HASP HL driver. Взять можно ftp://ftp.ealaddin.com/pub/hasp/hl/wind ... mdline.zip
Распаковываем и запускаем lmsetup.exe с параметром -i
Проверяем в Device Manager -> USB controllers наличие устройств Aladdin HASP Key и Aladdin USB Key.
Если нет таких, перезагрузка и заново пункт 7)
9) Установка HASP LM driver. Взять можно
Проверено на 14,16 релизах + sql2000 - работает запуск с консоли, через терминал, запуск оснастки 1с:сервер с установкой баз и работой в них
Проверено что sys реально 64bit - с sys последних версий, пришедшими от автора (win98,winnt 32bit), не работает 100%, те дело не в ключе реестра
Ищется человек умеющий писать дрова ( язык C ) и inf-файлы под winnt amd64
Don Vito & Jagular,
tnx to Chingachguk
jules
thanks
Post by jules »
Thank tou very much, but the dongle emulator for eplan still don't work
