I met a problem when I use PCS7 RT PO LICENSE.
I have install PCS7 RT PO LICENSE,but when I download the program, the system will message me that these is no PCS7 RT PO LICENSE booked.
I checked process objects statistics , found out I have configured 1124, booked 0, but available is 5000.
Why this happened?
somebody can help me?
thank you .
[?]: problem on PCS7 RT PO LICENSE ?
lshywt
lshywt
thank you ,I have read this,but I can not figure out where the problem is.CoMod wrote:http://plc.net.ru/viewtopic.php?p=16128#16128
Those are all my licenses I installed.
SIMATIC PCS 7 AS RT PO (5000) 7 1
SIMATIC PCS 7 Asset ES 7 1
SIMATIC PCS 7 Asset RT Unlimited tags 7 1
SIMATIC PCS 7 CFC - 5000 7 1
SIMATIC STEP 7 CFC STEP 7 Option 7 1
SIMATIC PCS 7 IEA 7 1
SIMATIC NET Industrial Ethernet S7-1613 6.4 1
SIMATIC NET Industrial Ethernet S7-REDCONNECT 6.4 1
SIMATIC NET Industrial Ethernet SOFTNET-S7 Power Pack 6.4 1
SIMATIC PCS 7 Maintenance ES 7 1
SIMATIC PCS 7 Maintenance RT 7 1
SIMATIC HMI OpenPCS 7 Station / WinCC 7 1
SIMATIC PCS 7 PID-Tuner 7 1
SIMATIC STEP 7 S7-DOCPRO V5. 1 5.1 1
SIMATIC STEP 7 S7-PLCSIM V5.4 5.4 1
SIMATIC STEP 7 S7-SCL V5.3 5.3 1
SIMATIC PCS 7 SFC 7 1
SIMATIC PCS 7 SFC-Visualization 7 1
SIMATIC STEP 7 STEP 7-BASIS V5.4 5.4 1
SIMATIC PCS 7 TH-PO 7 1
SIMATIC PCS 7 Version Cross Manager 7 1
SIMATIC PCS 7 Version Cross Manager (Import) 7 1
SIMATIC HMI WinCC Advanced Process Ctrl 6.2 1
SIMATIC HMI WINCC Arch (5000) 6.2 1
SIMATIC HMI WinCC RC PO (5000) 6.2 1
lshywt
CoMod wrote:Need info from diagnose reports
C:\Program Files\SIEMENS\WINCC\Diagnose\License.Log and Authorinformation.inf
WinCC versions ?fundov wrote:All Ok after installation of WinCC V6.2 HF2
WINCC verion is simatic WINCC asia v6.2 sp2
WINCC has no problem, and there is no this file(Authorinformation.inf)
license info.log:
07.10.2008 10:06:42 License_Info start -----------------------------------------------------------------------
07.10.2008 10:06:47 Is PCS7 project -> PO Licensing
07.10.2008 10:06:48 PO Licensing Mode -> POs:1125 Tags:38704
license.log:
10/07/2008 10:06:47 InitLicense RT | AppName = OptRT:CHIPCARD | CycleCheck = no | NameForMessageBox = | Name of License = A1WPC40602 | Text of License = |
10/07/2008 10:06:50 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WCP50602 | Text of License = WinCC RC PO (5000) | Relevant Limit = 0000005000 |
10/07/2008 10:06:50 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = SIFLA9WCP50602 | Text of License = WinCC RC PO (5000) | Relevant Limit = 0000005000 |
