REQUEST: Lauer PCSPROplus full
dofie
Post by dofie »
In PCS9100 need to find out level password.
Cable PCS733 is made by myself. Have problem to connect with PCSPROplus demo (i think WinXP is the problem) and don´t know right positsion of DIL switch.... Only info what i have:
2. Connect the communication interface of the PCS 8010 with the cable PCS 733 and check the rotary switch position at the PCS (switch position 2). Switch the PCS off and on again to read in the switch position again after modification.
Any help?
Later i try install Win98. But maybe anyone have PCSPROplus full?
thanлs
спасибо
dekor
My experience
Post by dekor »
Dear friend,
from my experience, on XP system it looks like it work.
But I can go on line.
I use W98, and work.
Try and tell us your results.
dekor.
dofie
win95 works ok
Post by dofie »
i find old notebook with win95 and trying with it. Now i successfully download soft from panel (after 3 try) and find out what i needed, BUT
now i add some language and trying upload back in panel changed soft ....
all looks ok and PROplus_DEMO say me - ok - its uploaded, but after panel reboot nothing change :( . If i try upload again PROplus say me - only 1 file is different - strange... may be need switch some DIL switces ? i don't have info :(
May be somebody help me with full version PROplus?
dofie
i get it.
Post by dofie »
I get full version PCSPROplus from LAUER HMI support. PROplus v2.2 with WinNT support. It work with XP! but need strong NO activites on background ( don't touch the mouse :). For now i have solved all my problem. Even no problem with russian menus...
Thanks for listen.
p1gar
Post by p1gar »
Dofie! I have the same problem with connecting to LAUER PCS 950 Plus.
I use the program PCSPROwin V7.3 Demo.
I was downloaded it from this link
[dead] :/12658800/PC ... rPanel.zip
When i try to connect to panel (upload or transfer), leds "SYS" and "COM" are blinking and than appear error "Please check connection to com_ check".
The programming cable i made by myself.
Do you can give me the link with full version with WinNt support?
I need to make backup from Lauer panel.
Thank you.
I am sorry for my english.
monty_burns_007
Post by monty_burns_007 »
So this rapidshare link is just a demo version ? Can PCSPPRO be used to download from under a XP PC ? If so I 'm interested in this version since my current experience is that you can only download from under W95 or older.
Monty 8)
p1gar
Post by p1gar »
Yes, it is demo version.
I'll try to use this program under Win95 if it is possible with my PC. :roll:
But Dofie sad that full version PCSPROplus v2.2 with WinNT support exist.
Alex1960
Re: i get it.
Post by Alex1960 »
dofie wrote:I get full version PCSPROplus from LAUER HMI support. PROplus v2.2 with WinNT support. It work with XP! but need strong NO activites on background ( don't touch the mouse :). For now i have solved all my problem. Even no problem with russian menus...
Thanks for listen.
Dear Mr. dofie!
I kindly ask you to upload
this program to rapidshare
or connect with me.
I have the same ppoblem
with PCS9000 - program lost
dofie
Post by dofie »
PROplus v2.2 with WinNT support - i get it FOR FREE at LAUER_HMI_support. If you want it just write to him.
Only differents between demo and full version is : after uploading you get the screen "DEMO VERSION" for 3 sec after every 10 min...
All other work without differences (i don't find any...).
p1gar - PCSPROplus don't work with PCS 950 Plus. Work only with PSC9000 and PSC9100.
Under XP (2Ghz) i try upload about 10 times - not sucess - best result is upload 98%
It work with XP! but need strong NO activites on background ( even don't touch the mouse !)
then run on Win95(pentium 1 ) - uploading works with 1st try.
Alex1960 - i send soft to you
sorry for my bad english
monty_burns_007
thanks dofie,
Will try it out.
What i do see your version only supports 2 newer panels.
In my older version or non NT version i can support almost all lauer panels.
On installation it searched my harddrive for existing versions.
Maybe i had to install my older full version and then yours to upgrade to NT serial download support for all panels.
monty 8)
p1gar
Post by p1gar »
Thanks for your reply, Dofie!!
chetanp2000
Re: REQUEST: Lauer PCSPROplus full
Post by chetanp2000 »
Can anyone upload PCS Proplus V2.2?
sajkat
Post by sajkat »
I have a similar problem to you. (lack of password)
I don't know what is the password on the PCS 9000 panel.
I have the original HMI project in which I found 3 passwords. Two of them are 4 digits length one is 3 digits length.
None of the 4 digits passwords works and I don't really know if it is possible to input 3 digit password. (maybe someone could help me - if there is some special key combination to accept shorter passwords than 4 digits). The passwords must have been changed by the machine operators.
From posts I understand that if I upload project from PCS to PC I will be able to check what are the passwords. Does it also work if the passwords were changed ?
If it's not a problem someone please upload the PCSProPlus.
kkzh
Post by kkzh »
Can someone offer me such software even at cost?
Regards,
kkzh
