[?]: Can I conect INTOUCH 9.5 with MPI comunication to S7?
nik_denev
Post by nik_denev »
Hi
Please help I am new in INTOUCH
I have S7-300 PLC without Ethernet CP can I conect it to INTOUCH 9.5 with MPI comunication?
Can somebody explain me step by step how to do it?
10X in advance for help.
Best regards
Schtiel
[?+]: Can I conect INTOUCH 9.5 with MPI comunication to S7?
Post by Schtiel »
nik_denev wrote:can I conect it to INTOUCH 9.5 with MPI comunication?
Yes, you can. See Device Connectivity Matrix.
Just use an appropriate wonderware device integration server.
nik_denev
Post by nik_denev »
Yes but how I must config all software part to can comunicate with PLC.
I have ArchestrA and try to use it but no have result.
Use CP 5511.
I not do something how must. :(
Umencho
Post by Umencho »
Hi
Just follow instructions here http://61.37.246.137/TECH/html/t001110.htm
regards
nik_denev
Post by nik_denev »
10X for help I will try it.
Hope that anything will be OK.
Umencho
Post by Umencho »
Hi
I hope so. :wink:
Regards and nazdrave :!:
bunglehead
Post by bunglehead »
nik_denev wrote:Yes but how I must config all software part to can comunicate with PLC.
Use CP 5511.
Just setup an general OPC Server (from Simatic.NET) to an MPI interface and use OPC Client object as a DI object. Should not be any problems with it. If it's a remote node (having CP5511) use remote suitelink server on it. I recommend 'old' OPCLink 8.0 instead of A2 FSGateway cause it's buggy.
