I can't activate PL7 pro v 4.3, 4.4, 4.5 ...I download three version but all have same problems...It say some ddl is missing...Its not opening...
but the registration part is ok, it opens and I can't activate it..I have no floppy drive to transfer license..the only way to activate is received code..
when I install above three at last it says some library problems ,it occurs 27 times...also it create problems to uninstall..
Please help me ......
If anyone have ProWORX v 2.0 (full version with part no,serial no etc) please upload here..I have the keygen for it..
[?]: How to activate PL7 software ?
vivek_luv4u
Re: [HELP]How to activate PL7 software
What dll? Post the full error message.vivek_luv4u wrote:It say some ddl is missing...
That's not a problem. Use floppy emulator (for example, try this one: [dead] :/71516714/virtualFDD.zip )vivek_luv4u wrote:I have no floppy drive to transfer license
vivek_luv4u
The error showing..
The error is:
when installing
Its showing.....
(a) 1st installation error family 1, family 2, family 3............family 27
(b) failed removing error family 1
(c) reinstalling error falimy 1
Then it Install in my PC.
After installing when I open it , it shows...."The execution directory does not contain the PL7.CFG file or the file contains incorrect information".
It install in directory C:\PL7...I also checked it by installing in another dicertory D:\, E:\..etc.but same problem occurs..
when installing
Its showing.....
