[?]: Change field of User Archive-Runtime.Table in Report
auric
Post by auric »
Hello!
I want to know, how I can change width of field of object "User Archive - Runtime.Table", that is placed on my Report Design Layout.
By default the with of all fields of User Archive have the same size, and i can't find, how i can change width value.
auric
Post by auric »
Sory, It appeared simply.
Probably, it'l help somebody...
Right Click on object->Check "Properties"->Check "Geometry"->Double Click on "Columns".
In popup window you can change width of each field.
00: 10 (relative)
10 - width of the first field of table in relative units.
