how can attach a pdf file or help file to Cemat blocks in CFC and open it when i select the block and press F1?
a C script or somthing like this, i think...
thanks
[?]: how can attach help files to cemat blocks in CFC?
actually there must be a help file under the folder which locates pdf file, plus
you need to enter needed information to the registry of the system. which means when you cpoy a block it will not copy help file.
[HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\STEP7\ 2.0\....]
[HKEY_LOCAL_MACHINE_\SOFTWARE\Siemens\STEP7\ 2.0\....]
try to browse down..you will understand it.
