[?]: I/O server Intouch <-> 2 plc connections via CP34
PLC_ITA
Post by PLC_ITA »
Hello friends, i need to connect 2 siemens S7 300 whit ethernet CP343-1
to existant supervision made whit Intouch 7.1
Already exist 1 plc and the supervision, i need to connect a second plc.
I don'k know I/O server and i have 2 question :
1) is possible ?
2) if is possible, how i need to configure ?
Thank's in advance.
PLC_ITA
Roman
SIDirect
Post by Roman »
Umencho
Re: I/O server Intouch - 2 simatic plc connections via CP343
Post by Umencho »
PLC_ITA wrote:Hello friends, i need to connect 2 siemens S7 300 whit ethernet CP343-1
1) is possible ?
Thank's in advance.
PLC_ITA
Hi
See here http://plc.net.ru/viewtopic.php?t=6660& ... assidirect more details about connection... :wink:
Or you can tell us how is made connection with first PLC ( I mean what kind of server is using...) and just to add other PLC... :wink:
OR IF YOU WANT TO READ ALONE :wink:
here http://61.37.246.137/TECH/technotes/estechnotes.htm :!: very usefull INTOUCH link.
regards
Roman
2 PLC
Post by Roman »
bunglehead
Re: [?]: I/O server Intouch <-> 2 plc connections via
Post by bunglehead »
1) is possible ?
It's possible for both DAServer and IOServer concepts of course. If you have an existing system based on version 7.1/7.11 most probably you use IOServer. I don't recommend you to switch to DAServer cause this toolkit still has some problems.
PLC_ITA wrote: 2) if is possible, how i need to configure ?
Thank's in advance.
PLC_ITA
For IOServer you have to configure another connection on existing Simatic.NET server.
For DAServer SIDirect you can use more than one PLC objects in configuration. DASS7 I think requires Simatic.NET too.
