i need CE standard cable color.
+24Vdc, -24Vdc, 220Vac, 380Vac, Notr, PLC digital input, PLC digital output, Analog input, Analog Output vs
Which color cable for control.
Thanks.
[?]: cable color
T = grey
Color code of AC power cords
European colors
* The live conductor must be brown
* The neutral is blue
* The earth ('safety ground') must be green/yellow
This comes from the harmonized cable standards, which are backed up by European legislation. Those color codes are used in fixed wiring, equipment cables and inside equipments.
Colors used in USA
* Green is earth,
* Black is live
* White is neutral.
In some cases the color of live wire can be red or blue.
