[LINK]: Malz Kassner: CAD6 Industry Rel 2008
Тools, Elcad, Eplan, ...
http://www.cad6.de
[dead] :/127605592/M ... l_2008.rar
35 mb
in Russian wrote:CAD6 Industry - векторный 2D/3D CAD/CAM редактор, самый оснащенный и удобный в своем классе.
Malz Kassner CAD6 Industry is the comprehensive 2D/3D CAD/CAM solution for industrial use. In addition to all features of CAD6 Studio the program includes a CAM plug-in and a universal, script-based post-processor for flexible and efficient generation of CNC data for machine controllers.
The CAM plug-in supports the following machining procedures: milling, drilling, turning, water jet cutting, laser cutting, cutting, plotting, and positioning.
Included are post-processors for:
>Universal DIN-ISO
>Siemens DIN-ISO (Milling) and (Turning) with the SINUMERIK 8XX controller
>Heidenhain DIN-ISO (Milling) and (Turning) with the TNC 4XX controller
>Heidenhain Klartext (Milling) with the TNC 4XX controller
>DATRON milling machine CAT3D
>isel NCP
>HP-GL
>Minimal HP-GL (using PU and PD only)
>and others.
Commands like milling cutter compensation, pocket milling, milling order control, milling time calculation and a graphical 3D preview let you create drawings that are directly milled later. Extensive tool and machine settings, plus output of custom commands (such as cycles or sub-programs) by means of symbols, give you the complete control over what the post-processors finally output to the machine.
OS: Windows All
