[?]: PC Adapter S7 can be a PLC?
hand_drake
Post by hand_drake »
Is true that PC Adapter S7 can be a PLC? (A master in the profibus network) :roll:
It very usefull for testing profibus components....
If it true? How? Thank's....
isn`t full plc only for diag.inform,not for set/reset/monitor I/O (for this you need check box "only master on the bus"in Set PG/PC Interface)
for full plc you can use WinLC or WinAC/RTX +your adapter
autho
Post by autho »
Hi sania,
may you explain more about working with winlc and winac/rtx?
