Dear All,
Need help.
I want to communicate s7200 CPU222 PLC using PC Access as OPC server and RS View32 as Client.
I stablished the communication between the two but the command coming from RSView not activated in the PLC only graphic animation activated on RSView command coming from the actual PB. I set write/read item on the PC Access.
If you have procedure regarding this problem please share
Many Thanks,
mike
