hello, can somebody help me.
I have a B&R MINICONTROL MCGE31-0.
which software do you need to progam it and where can i find some information?
[?]: which software for B&R MINICONTROL MCGE31-0 ?
megagastje
the old B&R PLC-Types like Minicontrol or Midicontrol (black-line) - is no longer supported through B&R.
Therefore you will not found any information on the B&R Website.
The Software for programming these PLC-Types is called "Prosys".
It´s an old DOS-Programm.
You also need a special interface-adapter to go online with the plc.
It´s a converter between the parallel-port of the PC and the Online-Interface of the plc.
You should contact your next B&R-office for further information or help.
megagastje
