how can add functions by using "uses:" command in SCL?
Can you explain with example about this matter.
Thanks advance...
[?]: How can add functions in SCL?
elektronikmuh
elektronikmuh
(* @PATH := '\/Building\/electrical' *) // And what is that mean this?
FUNCTION_BLOCK CLICK
TITLE = 'CLICK'
// Example below this PATH how can we introduce this??
//uses : oscat/engineering/measurements/T_PLC_MS
// oscat/engineering/measurements/STIME
VAR_INPUT
in : BOOL;
END_VAR
VAR_OUTPUT
Q : BOOL;
single : BOOL;
double : BOOL;
triple : BOOL;
status: BYTE;
END_VAR
VAR_INPUT
T_debounce : TIME := t#10ms;
T_short : TIME := t#200ms;
T_pause : TIME := t#500ms;
T_reconfig : TIME := t#1m;
END_VAR
VAR
debounce : TON;
tx : TIME;
last : TIME;
init : BOOL;
edge : BOOL;
standby: BOOL;
state: INT;
END_VAR
BEGIN
(* read system time *)
tx := DINT_TO_TIME(DWORD_TO_DINT(T_PLC_MS()));
(* set last and tx if never started before *)
IF NOT init THEN
init := TRUE;
last := tx;
debounce.PT := T_debounce;
standby := in;
END_IF;
(* debounce input *)
debounce(in := in XOR standby);
Q := debounce.Q;
(* delete outputs if input is inactive *)
IF NOT Q THEN
single := FALSE;
double := FALSE;
triple := FALSE;
status := 110;
END_IF;
(* check for input edge *)
IF Q XOR edge THEN
edge := in;
last := tx;
IF Q THEN state := state + 1; END_IF;
END_IF;
IF (q AND tx - last >= T_short) OR (NOT q AND tx - last >= t_pause) THEN
CASE state OF
1: single := TRUE;
status := 111;
2: double := TRUE;
status := 112;
3: triple := TRUE;
status := 113;
END_CASE;
state := 0;
END_IF;
(* determine if high or low active *)
IF tx - last >= t_reconfig THEN
standby := in;
last := tx;
END_IF;
END_FUNCTION_BLOCK-
graf_STEP7
Under SCL are // comments.// Example below this PATH how can we introduce this??
The Autor "Hugo" or "Daniel" will with the word "uses" say --> Copy the FB/FC with name "T_PLC_MS" and "STIME" in your projekt.
Your Funktion need this for Work without errors.
I allways use the OSCAT-Lib, it is very god.
do you have download your LIB for STEP7.
It is "READY to WORK".
elektronikmuh
Thanks for replay i understand,
i will try copy functions into my project.
Another question
this comment i dont understand what doest it mean?
Thanks in advance.
Another question
(* @PATH := '\/Building\/electrical' *)this comment i dont understand what doest it mean?
Thanks in advance.
graf_STEP7
This is an command to.Another question Code:
After open the lib, you can see Stuctur on Library.
(I dont know, if this multilingual, in german i see this in german)
I think, you have download the LIB for EXTENDED-SPSes
For Step 7 you can load an "ready-lib" for your system.
SCL-Source is in LIB aviable.
Follow steps:
Download LIB.
http://www.oscat.de/index.php?option=co ... cdesc=DESC
Urgend: Select "oscat.lib 2.74 für Step 7" for your System
Deutsch:
Starten von Simatic Manager
Datei --> Dearchivieren.. --> OSCAT.lib auswählen --> Zielverzeichnis und O.K.
English: ( I dont have English Version)
I will try it.
File --> dearchive --> select file and O.K.
You can open now the SCL and ready-compiled code.
Copy the FCs into your Programm.
You can rename the Function-Names.
You can open to: File --> open --> Tab Library -->
Have Fun
