Dear all,
do anyone know how i can copy a .266 file to the positioning module
since when i try to connect to the module (become online ) it gives me an error F53
which states that either the cable is not connected
or there is no power supply although i am sure that they are both working fine.
i have another question does the serial port needs a specific settings ?
[?]: IP 266 (Positioning Module ) for S5 systems
kaffeemuehle
hi , actually the cable that i am using is a PG cable and it works fine with the PLC. However, i don't know why it gives me such an error.
1) I connected the IP 266 card to the bus interface with a 24 V power supply
2) i attached the cable from the PG to the positioning module
3) i started the COM 266
4) i Pressed F2 to get online
is any of these steps wrong ? or there is something missing and what maybe else producing this error
kaffeemuehle
