[?+]: transfer Floating License Key thru email or internet
charles_ch_tan
Post by charles_ch_tan »
hi, anyone know the way how to transfer the Siemens Floating License Key thru the email or internet and install to another PC which is very far away.
Umencho
Re: how to transfer Floating License Key thru email or inter
Post by Umencho »
Hi
If I understood the question... :roll:
Go on System Tools in windows and start backup wizard. Choose from yourselves the folder with installed keys (AX NF ZZ), put some name and you will have a backup of every installed keys (less then 2Mb). This file you can send by email, and on the other PC, you just need to start restore procedure. :lol:
regards
brainless
Post by brainless »
Hello!
You can use the official Siemens program Automation License Manager for that: look at License Key->Offline Transfer.
See ALM Help.
brainless
charles_ch_tan
Thanks Umencho and Brainless helps.
Umencho Method:
It does not work. After i restored from what i had back up, the Lincense Key was created but Lincense show at Automation Lincense Manager, Number of the License = 0.
Brainless Method:
I had follow the way from Generate Start Code until Generate Activation Code. What the Request Code and Activation Code that I key-In is not valid. Finally it will delete my existing Key as well.
Once i load back using offline Transfer, the key does not Active.
Sigh~~~~
Any others way?
For Umencho method need use USB stick
http://plc.net.ru/viewtopic.php?p=6624#6624
Brainless/ALM offline Method 100% but need generat text files with codes and attentiveness
You can test with keys from EKB_Install
in Russian wrote:Оба метода работают,
Но для создания образа удобнее использовать любую USB Флешку.
ALM offline метод 100% работает, но лучше для кодов использовать генерацию файлов с кодами и быть внимательным в последовательности.
Потренируйтесь для начала на ключах из EKB_Install
