[?]: How download program from CJ1M PLC ?
CX-One, CX programmer, NTST, Syswin ....
nguyenthe_k
Post by nguyenthe_k »
(( Hi, I'm newbie to PLC world. So please don't laugh at my stupid question. :oops: )
I am trying to connect to a CJ1M CPU21 but the PLC seems does not detect my cable connection - RS232C. These conditions have been virified by me:
The CPU setup (CJ1M CPU21) is correct.
The connecting method is Toolbus.
The com port is correct ( in this case, I set the cable port to COM1)
The 5th dip switch in the PLC was on.
When I first pluged in my cable, the COMM indicator was light up, but if I tried to connect to PLC, it switched to off.
The cable I am using has been vefified and connected successfully to the other PLC (CQ1M...), but not the series CJ1M ???
In my case, do I fortget something important ??
most
Post by most »
CJ1M, it never passed for my hands but I give a small help with manuals.
http://www.idom.ru/files/Omron/FA/Manuals/Plc's/
read 340, ..., 345, 380 and 336
the cable for CQM is not for CJ. i think
if to obtain what you intend says some thing because also I am interested for the future. :wink:
best regards
nguyenthe_k
I've found the cable serial diagram of CQM1, anyone has the rest.
[dead] :/116009827/O ... d.zip.html
The CJ1M and CQM1 actually share the same cable diagram. Look at this documentation.
[dead] :/116032717/O ... g.pdf.html
Anyone has the experience with this ?? Please help !
most
Post by most »
you did not look very well ...
this is the cable (if it is equal to CQM, ...I did not compare ...)
with switch 4 and 5 tries on off ....
with cx programmer chooses "Auto Online" or the "Sismac Way" in manual.
search with google this manual "W393_E1_07_CJ1_Operation_Manual.pdf" +- 12 Mb
this pdf have all that you need.
edit
[dead] :/116076634/W ... l.rar.html
your cable is for HMI Proface (if it is equal ...i did not compare...)
regards
Husanto
Connect PLC CJ1M
Post by Husanto »
You can try with this :
1. Turn On the dip switch pin 5
2. Set in your CX - programmer with default setting, baudrate 19200
3. check u Comm port, it must same with auto detect in your PC COMM
4. Using sysmac way Communication
5. Try to connect again.
Hope this help...
Husanto
